Mitutoyo DRO Manual?
Nick Hacking
Jan 22, 2017
90
Dear All,
I have a Bridgeport, recently acquired, and am only just starting to learn how to use it. It has a 2-axis Mitutoyo DRO which appears to work: I can get it to zero and the X and Y numbers move when I move the table. I can switch between inches and mm... and that's about it.
I think the DRO itself is a fairly standard Ka-Counter unit, but I cannot find a manual for it anywhere on Mitutoyo's web sites. It looks as though it can do a bit more than the functions that I've found, but I haven't a clue.
Can anyone point me to a users manual, or, failing that, tell me how to use the thing properly?
Many thanks,
Nick
Can you post a picture of your digital readout as well as the model number for a start. I have a manual or two, if I can find them that are for some of the older digital readouts Mitutoyo sold and don't support today that may help a bit. Ken
Thanks, both.
No: that's not quite it.
I would go out to the workshop and take a picture, but it's very late and very cold. I'll post back in the next couple of days.
Kind wishes,
Nick
Here is is. Sorry about the camera wobble: it looks like it's a KL-12.Mitutoyo Front.jpg Mitutoyo Rear.jpg
Nick,
Mine is a little older that yours. The scales may be the same but the readout is newer. Mine don't have all of the pushbuttons on the front. Just one to reset X-Y to zero.
Sorry, Ken
Thanks for trying to help, Ken. It is appreciated.
I wonder what all the buttons are for? I suspect that it can handle trigonometry calculations, but how is beyond me.
Kind wishes,
Nick
I'm still plodding away with this, eight months on!
The pdf is helpful, but it's not specific to my model and doesn't cover everything, nor does it explain how to use the different functions.
I've worked out what some of the keys do: it helps that pressing key inappropriately produces an audible "beep". If anyone knows how to use the ones that I'm stuck on, I'd be very grateful.....
The yellow "X" key sets the X-axis counter to zero.
The yellow "Y/Z" key does the same for the Y/Z counter.
Of the blue keys:
Top row, key 1, marked I/A, selects between incremental and absolute measurement.
Top row, key 2, marked with a solid inverted triangle. Turns on a little green LED adjacent.
Top row, key 3, marked with a pictorial of an end-mill (?) and a workpiece (?). Turns on a little green LED adjacent.
Key 2 turns off key 3's light and vice-versa, so whatever they do, they're mutually exclusive.
Top row, key 4, marked "HOLD" I don't know what it holds.
Second row, key 1, marked "X", allows data input into the X-counter.
Third row, key 1, marked "Y/Z", allows data input into the X-counter.
Fourth row, key 1, marked "ON/OFF", turns the unit on and off
Fourth row, key 2, marked "UNIT", selects between mm and inch display
Fourth row, key 3, marked to suggest that it's for making sequential cuts, turns on an adjacent LED, but I cannot work out how to use it.
Fourth row, key 4, marked to suggest that it's for cutting at several points around a circle, I have worked this one out. It also has an adjacent latching LED and it and key 3 are mutually exclusive.
Fourth row, key 5, marked "1/2", when either the X or Y/Z counters are accessed, this key halves the counter's value.
Fourth row, key 6, marked "CE", appears to cancel the last key entry.
Fourth row, key 7, marked "LOAD", seems to function as an "enter" key. Also used to toggle between co-ordinates when working around an arc or circle.
If anyone has a clue, please let me know.
Many thanks,
Nick
