H
Hukshawn
Forum Guest
Register Today
so, I've seen a bunch of videos of guys using the mister lube sprays. I like the idea. That it will cool and lube and blow the chips out of the way of the cutter, mill or lathe.
So I ordered a cheapy off eBay to see if I like it.
The question is, for those of you who use them, what lube do you put through them?
I am not too up to date on water based cutting lubes. I'm not too sure what's available around me either. I grabbed a water based cutting lube from busy bee a while ago, but I'm not sure how I like it. But I wonder if it can be diluted and misted.... the product is linked below.
http://www.busybeetools.com/products/cutting-fluid-16oz-relton.html
What's the white water soluble lube I see most pros using?
