- Apr 12, 2011
- 3,419
Does anyone have and use this protractor? I am wondering if it is a handy tool to have in the toolbox or would it just take up space. And let's not dwell on cost at this time, thanks.
Miracle Point Magnetic Base Protractor
Erick Miracle Point Magnetic base protractor and center locator is used to locate the middle point of any object positioned within the V leg. The center pin will mark the middle point at the angle being indicated, and also can be used instead of ruler and scriber to located drill point in center of flat stock, square stock, round stock, hexagonal stock add to infinitum...
Features:
Specifications:
Guaranteed Calibration± 1/2° for One Full YearDial Face2"Height5 1/4"Width5"Depth1"Weight16 oz. w/casePackagedOne per box
Here is a link for more info.
http://www.penntoolco.com/miracle-point-magnetic-base-protractor/
Features:
- An extremely accurate protractor with extremely sensitive, sealed mercury balanced needle
- Protractor is permanently attached as an integral part of a powerful Magnetic V Base containing lifetime Alnico magnets
- V base is precision ground
- Gives immediate readings of angles for full 360 degree radius
- Protractor set in cast aluminum housing
Specifications:
