    Dismiss Notice
Mini Mill Torsion Arm Screw
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by ferlum, Feb 16, 2017.
  1. ferlum
    ferlum United States Active Member Active Member
    46
    18
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    Figured I'd post this here in case anyone else runs into the same problem, and as a heads up to check your machine if you're still using the torsion spring arm like me (haven't gotten around to the air spring upgrade).
    I had a thin workpiece clamped directly to the table and couldn't lower the head far enough to do what I needed. It was bottoming out in the torsion spring arm so I had to take it apart to get the extra inch. Once apart I discovered that the big screw was badly worn. See pic. LMS has replacements but they're more $ than I think they're worth so I got this shoulder screw from McMaster for much less.
    Anyone still using the torsion spring might want to check the screw for wear -- it could get ugly if that thing lets go.
    The shoulder screw is 10 mm Diameter x 12 mm Long Shoulder, M8 x 1.25 mm Thread Size
    McMaster PN 92981A300
    [​IMG]
    bmac2, roghmc, clevinski and 4 others like this.
Share This Page
