I've got a question about the tapered bearing upgrade. Question being are the bearings open? and if so how do you keep trash out and grease in?
I am in the midst of this upgrade. Plus painting my lathe.
The tapered roller bearings are open and you need to pack them with Grease. I could not find sealed ones.
you can make gaskets I seen on this link under the head stock upgrades on the right column.
Also check out some of my other threads & post for my lathe As well as Brians site.
Canadian bearings link
https://www.bearingscanada.com/
Mini lathe mods
http://www.toolsandmods.com/
LMS has the parts and you can speak directly with them to make sure of the part #'s you order and need,
I like to make my own parts if I can.
There are a lot of different web info sites and a few youtube videos for this.
Make yourself a good plan & a list of the details you want for the mod.
You will need to make a few items before you tear down your lathe. Or make them on another lathe.
I just read as much as I could chose what works for me. Plus some of my own ideas.
Such as adding Grease fittings or tapped & threaded access holes to the head.
I will post my decision on that one later.
ok I'm done rambling only on my first coffee....
