I am in the middle of making Harold Halls Deluxe Grinding Table. I need to mill dovetails in several parts. The dovetails are 60° and 8 mm (.314 in) to 8.5 mm (.335 in) high . As I'm getting ready to order my first dovetail cutter, what size is recommended?
I will be ordering the cutter from LMS and sizes available are 3/8", ½" and ¾ in. The cost difference isn't that much, but I don't want to order all three now.
Any other comments on milling dovetails welcome, as I've not done them before. Speeds and feeds? DOC? Multiple passes? Material is mild steel. Mill is an HF X2.
Go easy on this noob, eh? Thanks in advance.
Chuck in E. TN
Chuck in E. TN
