Metex DM-45 mill help please
Rick in the shed
Swarf
Registered Member
Jun 7, 2017
2
Likes
1
#1
G'day , does anyone know much about metex dm-45 mill, in general, as I'm new to all this any info would be great, but in particular ,lifting points - how to sling properly , and PDF manual ,thanks
Downwindtracker2
Active Member
Sep 5, 2014
125
Likes
34
#3
It looks a lot like one of the generic clones of the Rong Fu 45. I would check Grizzly for a on line manual.
For slinging , I forgot how I did mine, but if you use a nylon sling and double wrap the column , crossing your eyes under the gearhead. That should get you close enough for your balance point. A nylon sling will choke on the column and carry a fair bit of weight. Lock your head, and for the sake of your feet, stay out from under it.
Container Above bottom breadcrumb
