  • NOTICE: There are two new video channel areas set up, one for staff, and one for subscribing members. You need to create a folder. Then add your media to that folder. Once added, you can cut and paste the code at the bottom right to embed the media into a post on the forum.
    It works very similarly to YouTube, except videos are stored on our server. Click Here For The Video Channels
[4]
Members' Tooling "Wish Lists"
[3]
[10] Like what you see?
LogansRun
Iron
Registered Member
Nov 26, 2015
13
Likes
2
#61
I'm looking for a new tool post for my Logan 2527 Lathe. The one I have now limits proper use and doesn't stay tight under load. I'm looking at two choices and am chomping on the bit to order a.s.a.p.
They are both from China so is one better than the other. Should I save for Aloris?
http://www.ebay.com/itm/281827797886?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT EL CHINO CHEAPO
http://www.ebay.com/itm/300435914635?_trksid=p2055119.m1438.l2648&ssPageName=STRK:MEBIDX:IT CHARS
Here's what I have now.
malar
Iron
Registered Member
Nov 12, 2015
12
Likes
0
#62
I have the same kit as the plunger type T.P. you have a link for. I'm pretty happy with it so far.
It's claimed the wedge type T.P. is better if you can afford a few more bucks.
You have to machine the bottom plate (or nut) to fit your cross slide.
I did that in my shaper.
Only problem I have not run down yet is the T.P. will pivot when tightening the locking handle.
I don't think it is a problem with the T.P.
hman
Feb 17, 2013
1,542
Likes
1,062
#63
The solution to unwanted tool post rotation is to chuck the body up in the 4-jaw and relieve the bottom between the center hole and maybe ΒΌ" from the nearest face. Don't need to go very deep - .015 is enough. What this does is to move the friction between the slide and the tool post to the perimeter of the tool post body.
Removing the innards from a wedge type is pretty easy - just unwind the adjuster.
For the piston type, rotate the adjuster to bring one piston out as far as it will go. Grasp the piston with a pair of vise grips. Rotate the adjuster until the other piston is all the way out. The adjuster can then be pulled out. Once the adjuster is out, you can let the pistons pop back inward, then grab each one (to keep it from turning) while removing the socket head screw.
mmcmdl
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jan 31, 2016
376
Likes
303
#64
Looking for a D1-6 Jacobs flex collet closer . I have a LO or a LOO spindle mount if someone would be willing to swap 1 for another . Lots of other tooling to trade . Thanks . Dave
RIMSPOKE
Active Member
Active Member
Jan 16, 2016
234
Likes
574
#65
I'd love to get my hands on any 5C collets in sizes apart from 1/16" increments... That's my wish...
DO YOU MEAN LIKE THIS ?
1/64th SIZES TO 1.125 " , HEX , SQUARE , EXPANDING AND TAPERS
THE 5C MOUNT 4" SIX JAW BUCK CHUCK IS ONE OF MY FAVORITES .
[6]
[5] [7]
