- Jan 21, 2013
- 862
After spending a while turning hardware store steel rod down in various ways, one attempt at threading (successful) and learning how to use the DTIs correctly, I've been noticing some signs of the stock being crooked that may not have been my fault after all. I decided it was time to do some testing and truing up on the chucks and faceplate and started with the 4 way chuck's adapter plate (wow, it's off in nearly every way!lol). I noticed while facing the main "face" of the adapter that the cutter was floating as it got near the hub, and it was only slowly coming on plane as I deepened the cut. I was only taking 2-3 thousanths at a time so that I could see what was happening, so not much was removed before I saw that. I had a suspicion and decide to DTI the face of the spindle. I had tested it for runout when it first arrived, and it was as close to zero as I can determine with the cutter marks still there, but I hadn't tried testing for tilt . I'm getting consistent measurements of an almost perfect .001 difference between the back and front side of the face, in the direction (away from the operator) that I would expect from how it was cutting. The outside 3/4 of the adapter is nice and flat now and it also shows that amount of variance. Crap.
I'm assuming that this is an unacceptable amount of skew. Am I right, and how bad is this going to be to fix (referring to other pm1236 owners here.). It's difficult to determine what bolts are involved for this.
Any help?
Any help?
