4
material organization
3
Like what you see?
10
cs900
maker of chips
Active Member
Mar 21, 2016
179
Likes
192
#1
So I guess I'm not sure where this fits in the whole format of this forum, but I'm in the process of cleaning up the my metal shop, and one thing I've never been happy about is material storage. I have a small shop and space is at a premium so I'm looking for good ways to store material in a compact and organized fashion. So how do you guys organize and store your bar stock, cut-offs, and other general materials?
q20v
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Dec 12, 2012
105
Likes
287
#2
I used to keep it all (about 15-20 bars, from 1"-15" lengths) piled in a corner of the work bench. Last weekend I moved it all into a small tool box, as seen below (the 4-drawer box in the middle of the three):
I also have a few longer lengths (about 3') and they're just sitting on the floor until some else responds to this thread with a good idea that I'll steal...
cs900
maker of chips
Active Member
Mar 21, 2016
179
Likes
192
#5
some great ideas already! I'm currently doing the PVC organizer trick, but generally find it to be terrible. Or probably more accurate, my implementation of it. haha.
dlane
Sep 27, 2014
2,222
Likes
885
#6
I made this rack that holds milk crates , although 6 gallon crates are getting hard to find,
works good for small stock , parts , paint cans, supplies
It holds six crates , I put the heavy things in the bottom two slots
RandyM
Staff member
Apr 12, 2011
1,809
Likes
1,356
#8
here is what i did :grin:
(unistrut and 1/2" unf allthread)
Hey UD, from that angle in your picture it doesn't look like the garage door and stock rack like each other. You sure you have enough clearance to open that door?
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,297
Likes
3,495
#9
Hi Randy, Yes sir there is about an inch clearance between the door and the unistrut
here is a picture with the door up!
RandyM
Staff member
Apr 12, 2011
1,809
Likes
1,356
#10
It just looks more deceptive in that first pic. It's nice to use space that normally goes wasted. Nice job.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,297
Likes
3,495
#12
Hi GoceKu
I have about 350 lbs of materials resting on the unistrut, there are 3 supports
GoceKU
Active Member
Active Member
Jul 14, 2017
253
Likes
399
#14
Ulma Doctor, that's very respectable, not sure if i would like that much hanging above my car with all the vibrations of my diesel car under it. Cool design, nevertheless, thanks for sharing it.
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#16
Is a garage for cars, or our fun stuff. Well, I will take that back my wife has our freezer in the garage as well. But like UD have not been able to park a car in it in almost 20 years, but I only started doing lathe about 3 years ago. Welding, Wood work, also in a one car garage.
dulltool17
Active Member
May 9, 2014
240
Likes
142
#17
"until some else responds to this thread with a good idea that I'll steal..."
Shamelessly, that's how it's done....Shamelessly.:D
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#18
Which one, There are a lot of good ideas in this thread, In fact I have some old rack slides for mounting servers, that I was thinking of redoing to make some slide trays, to go on the metal table I made to go under my lathe, That way I can put stock on it. as well as my chucks. etc. Other than that I 'm thinking the PVC pipe to make holders.
KenS
Active Member
Aug 2, 2011
144
Likes
22
#21
Just a small garage shop here, but using about 12-feet of 4" PVC pipe, scrap wood and an $11 Harbor Freight dolly (bought on sale for $8), I built this little cart to organize some of my metal stock.
The HF dolly is rated at 1,000 pounds, so even if you down-rate that to a more conservative 500 pounds, there's still plenty of capacity. The rig rolls really easily -- even over shop mats -- and there's no tendency to tip.
What's really nice is how much material you can store when it's vertical, and how easily you can locate what you need. It's been a handy addition to the shop.
Ken
Glenn Brooks
Nov 14, 2014
651
Likes
664
#26
Seeing this thread I decided to do something about the various stacks of materials I've got laying around the shop. The long stuff I leave on the floor behind the lathe. Other random lengths get stacked in the corner next to my welding and grinding tables. Usually I throw the short random pieces into a box , mostly to never reappear again. So decided at least, to have a go at organizing my short to medium length materials - all thread, round stock, and some flat bar stock - up to 6" to 24" long.
So, welded up a simple frame to horizontally stack 24" lengths of six inch PVC pipe. I made the frame to sit on a shelf on one of my storage cabinets. Here's the result. So far so good. (P.S. The frame could sit atop a small square steel storage rack, if I ever get that far down my Project list.)
Here are the raw pieces for the frame, before cutting and welding - lengths of square and twisted bar stock from our old front door railing.
End result - 5 pieces of 6" PVC pipe loose stacked in the frame. Filled with various round stock.
IMG_3514.JPG H
Here's the frame. 18"x14" with 9" uprights to hold the pipe sections
Close up of the frame construction - still needs to be cleaned up and painted.
I figure I could stack more pipe sections to make a third and forth row if needed - by sliping lengths of 3/4" square tubing over the uprights, and adding more layers of pipes. So far, don't have a need to do so.
And one more view with materials
6
5 7
