- Oct 11, 2013
- 90
Greetings to all;
This is not really an Atlas issue, but I will (hopefully) be creating the taper needed on the lathe.
I've got an automotive project going that requires replacing the steering shaft. The lower end of the 3/4" O.D. shaft will be pinned with a roll pin to a cupped receiver that's tapered on the inside, about 1 1/2" long.
What is the best or most straightforward procedure to replicate the internal taper of the cupped receiver onto the shaft end?
As always, thanks in advance!
Lou O.
Lou O.
