I have decided to try making a couple of indexable tools for my current project. I want to make a 90° Countersink, and a 60° dovetail cutter. I will follow Bob Warfields' write up on the dovetail cutter, and Chris Heapys' write up on the countersink.
Bob's Dovetail Cutter http://www.cnccookbook.com/MTMillDovetail.htm
Chris's countersink http://www.astronomiainumbria.org/a...ca/easyweb.easynet.co.uk/_chrish/csknotes.htm
I have been researching/studying insert info and have chosen TCMT inserts for both.
What I can't find is the screw size information for holding the insert on the tool.
Where do you find this info? Do I have to buy the insert and determine the screw from that, or is there a chart or reference for insert mounting screws?
Any other input? Examples of tools you've made?
I have a bit of O1 ½" drill rod (silver steel) to work with, or would regular steel shafting work?
Chuck in E. TN
Chuck in E. TN
