- Jan 20, 2016
- 602
I have been trying to make some reamers recently and I am having some trouble getting the geometry correct.
The most info I have been able to find just says to turn a rod to the right diameter, then cut it in half. I tried that and it didn't go very well the first time. I had trouble with it skipping around over the hole before it dug in and started cutting.
Then I tried adding some angles based on a video I saw where it worked well and that went ok, except I overshot it a little when cutting in half and it was about .005" undersized and when cutting, the hole had a poor finish and was oversized by a good bit.
Instead of making 5 more until I get closer, I figured I would ask and get some guidance first.
Ill add some pictures so you guys can see where I am.
I was working with a piece of O1 tool steel that I turned down to .2501", then stuck it in the spin index on the mill and cut it in half and cut a bit away at the back end. Then cut the angles. I hardened on the drill press while spinning using a propane torch and mapp gas and quenched in used motor oil. Then cleaned it up a bit and sharpened on a stone.
Any help would be great.
