Here's the story: I purchased a PM25mv mill with base. My garage floor is not level, sloped for drainage should I hose off the floor. I grouted the welded sheet metal base to the floor (measuring on two of four edges) to be within a couple of thous and bolted it down. The top is way not flat (thin welded sheet metal). There was no way to get even close to flat just bolting the mill to the base. I leveled the mill using washers and shim stock (the welded top is all over the place measurement wise). Got it within an couple of thous. The cast iron base of the mill is set on roughly 2 square inch of support at the corners.
My buddy programs Mazaks and is lecturing me on the need to come up with a more solid contact with the base to dampen vibrations. My argument is that no mater how this mill is mounted on the current base, the thin sheet metal base will resonate at certain speeds/cutters no mater what I do. I could make a 3/8" machined top plate welded to 3/8" stand to solid it up. I'm not sold that this is necessary (but obviously preferred). I searched for an aftermarket stand built tougher, but found none. Your thoughts? I can make a bull base for this thing...Should I? I intend to eventually convert to CNC.
