- Jan 31, 2012
- 212
There I was, installing 220V in my workshop, when my neighbor walked in saying "do you think you can help me?" and shows me this hub.
It is part of a Mongoose bicycle equipped with very fat tires. To accommodate the wider wheel, the manufacturer created an extension to the regular-sized part.
The extension is welded to the rest, but in this case the weld is not on the seam, it is right NEXT TO IT. Kudos for quality control!
With maybe 20 thousands worth of filler holding the 2 parts together, the inevitable happened and the joint broke.
According to my neighbor, the owner's forum is full of reports of the same failure. Not just one miss, but a whole batch of them.
The fix was fairly simple:
- turn off the existing weld
- bevel the joint
- braze both parts together
- turn the joint smooth
Don't you just love a grateful neighbor?
- bevel the joint
