    Dismiss Notice
Lug on the back of dial indicators
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by CarlosA, Feb 15, 2017.
  1. CarlosA
    CarlosA United States H-M Supporter - Premium Content H-M Supporter-Premium
    45
    28
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    I have always held mine by the stem below the dial... is the lug designed to be bolted to?
    I am making a new dial (drop) indicator holder and want to maximize space this time, when clamping by the stem it always seems to be in the way. I wasn`t really sure if the lug is meant to be rotated and permanently bolted to, or if there is some special mount.
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,798
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Yes, the lug is for mounting the indicator, and so is the stem. Either can be used. If you use the lug you normally will need an adapter to fit between the stand to the indicator.
    mikey and darkzero like this.
  3. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,513
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    As Bob mentioned yes the lug is also meant for mounting. AGD2 indicators have a 3/8" stem as a standard for mounting but I never liked using the stem for mounting.
    My dial indicators are Mitutoyo & have dovetails on the case. So I use a flat back & use the dovetails for mounting on my Nogas. Otherwise I would make an adapter to bolt to the lug back.
  4. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    177
    43
    City:
    nipomo
    State:
    California
    -Return to Top-
    the adapter I have screws to the hole in the lug with a nut bolt configuration then there is a 1/4" shaft that protrudes and mounts to a standard dial indicator swivel. bill
  5. kd4gij
    kd4gij United States Active User Active Member
    1,177
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    The lug can be rotated 90deg and mounted to a stand for a drop indicator .
    [​IMG]
  6. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,350
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    I see it mentioned often, what is a Noga?
  7. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    441
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Noga is a brand.
  8. darkzero
    1,513
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
  9. Wreck™Wreck
    1,350
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    You are correct, I suspect that I do not connect the name with the tool as an everyday description.
    I just consider everything a generic indicator holder for general use.
  10. dlane
    dlane Active User H-M Supporter-Premium
    786
    113
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    Are they related to nogahide:confused:
    TomS and f350ca like this.
Share This Page
