- Feb 7, 2013
- 792
I dont know if this is good advice or not I have had trouble with my GO727 knee mill. The problem is when you get the gibs tight to where the machine works well the knee or table will stick and shudder when you crank it up or down. I have tried everything short of a different gib like brass or even plastic. I was prepairing to make a different gib with some relief in it for less surface contact when I started checking into lubricants I tried everything I could think of way oil, Synthetic motor oil of different brands, slick 50 grease, Slick 50 oil, even Never Seize, nothing worked.
I dont know why but I picked up my bottle of straight STP it comes out just like honey I use it for open gears it really sticks well so I thought what have I got to lose? So I gave it a couple shots cranked it up and down and to my utter suprise it was smooth as silk. I had know idea something this simple would be the cure I was dreaming up all kinds of mechanical ways to cure the problem and ignored the simplest solution. It works great now,,, hope this will help someone.. Ray
