- Jul 20, 2012
- 1,237
What kind of material removal can I expect to get with the sherline mill working on 316L stainless. ie. How fast of a feed with 0.1 inch depth of cut, cutting out a channel with a 1/4 inch cutter can the mill handle? I'm planning on having most of the material removed on a water jet cutter first.(there are 7 fab shops with water cutters close by and they have reasonable prices) So the milling is to bring to final tolerance and chamfer some radius edges. I'm just wondering how much material removal in cubic milimeters/minute the machine can handle without too much deflection. That will roughly tell me what I can expect to set my speeds and feeds to for each operation and thus how long it will take to make the everage watch case.
Looking at the sherline lathe vs the mill, the lathe seems to be able to handle way more material removal, which has dictated alot of how I'm planning my setup.
Granted the only parts I'm concerned about speed on are the case parts, the watch guts take forever always.
Be sure if you can to actually see and hopefully use a little any machine you are considering.
