- Feb 24, 2017
- 8
Hello Hobby Machinists, My name is Jamel and I am a New Yorker that has been living in Osaka, Japan for over 5 years. I am an automotive enthusiast so I have used tools like drill presses, impact wrenches and angle grinders but for what I am trying to do, I hope to be a bit more precise.
I have a set of car wheels that are three piece welded construction.
The Inner Barrel is welded to the Outer Barrel all around the circumference and I am looking for a way to cut the weld to remove the outer barrel from the wheel assembly.
At the moment, I simply have the wheels and a spare wheel hub from a car that will allow me to rotate the wheel if attached to a spindle of some sort.
What I am looking for is ideas on how to precisely cut the wheel apart (Simple or complex)
I assume a lathe would be one way to do it but I don't know what size lathe I would need or if there is a more analog way I could do this within limited space constraints.
Any Ideas or input would be appreciated. If you suggest a lathe, what size would be able to cut apart a wheel that is 17-18" in diameter?
I'd be very grateful for any assistance and advice!
(Note: I tried to attach photos to help explain but it wouldn't let me create the thread with the photos...)
