Looking For A 90 Degree Swivel
ex_isp
Sep 6, 2016
113
I need two pieces that look like a tie round end but can stand rotation at about 4, 360s per minute. This will be for a crankshaft throw on a power hammer. Eccentric mounted plate moves a connecting rod (needs to be grease-able)up and down by circular rotation.
Any ideas? I'm not even sure what this part is called... If I'm not specific enough, I can find somewhere, a photo.
Thanks!
Ex
I think what you are describing is a connecting rod bearing. But you want it to look like a tie rod end? Maybe a Heim joint or rod end is what you're looking for.
https://www.mcmaster.com/#rod-ends/=14txz9d
You'll probably end up making it using a couple of heavy ball bearings.
