Long Chang LC-30 CNC conversion
slow-poke
Dec 9, 2016
328
Well with advice from this forum, I now have x-axis CNC working, Y and Z still to come. It was easier than I expected.
I have not had time to optimize the motor speed yet, however it's quite accurate (< 0.001" on test runs of 6" travel). I'm still using the original ACME screw with a lot of backlash, so when I change direction the errors do accumulate, typically by about 0.001" per change, will need to see if I can tweak it a bit.
I get most of my metal from the scrap metal recycler ($1 per pound) so the 1/2" plate I used for the bracket was a bit rough but does the job.
Thanks for all the suggestions.
BTW Motion Industries provided the belts and gears (two thumbs up), exceptional customer service.
  • 20170728_103555.mp4
This is a round column mill like the RF-30? I want to convert my RF-30 to CNC. I make bullet molds on my lathe and mill and it would be nice to be able to cut the cavity on the mill.
FYI, this thread is about 3 years old, so you might not get a reply from the OP (original poster). Jim Dawson (rhymes with awesome) is a monitor here and will probably chime in on your thread asking for "where to start". I bought ready-made machines (Tormach and Bridgeport), so can't offer you much advise. You'll likely need things like ball screws for the table, servo or stepper motors for each axis, a controller card like a Centroid Acorn, drivers for the axis motors, maybe a new spindle motor to put it under CNC control, a controlling computer/laptop, etc.
Forum member "macardoso" did a wonderful job posting his "journey", though not on a Rong Fu mill. For the life of me I can't find his post but with a little digging you should be able to find it. Member "cooter brown" did a nice build on a Bridgeport, you can hit his thread and it'll give you an idea of what is involved.
Bruce
I have a Long Chang mill exactly like the OP’s.
It is a very close facsimile of an RF-30.
