- Feb 5, 2014
- 198
Had this Logan for 10 years and my Grandfather 50 years prior. Has served me well cutting soft stuff but recently noticed movement in the chuck and took it apart to investigate. I have a few questions i hope i can get answers to.
1. Are the spindle bearings pre-loaded or are they clearance and get their pre-load strickly from the take-up nut on the gear drive side? I found my take-up nut rather loose found but there is play in the main spidle bearing when it is not mounted. Mainly axial.
2. What torque should the take-up nut be set to?
3. I figure new spindle bearings are smooth as silk. Mine are not super rough but not super smooth either. When do you decide to spend the $100 for a new one?
4. I put the spindle back into the bearings and housing without the drive pulleys and gears. I tightened the lock-nut moderatly and measured the run-out. It measured .0006". I deflected the nose in all four directions getting ~.001" deflection but always returning to within .0001" If i spin the spindle at that point (with a chuck on it) it will spin free for about 45 seconds. Does that all sound right?
(Edit July 2020) You can also see my install of a QCGB here. here
