- Nov 14, 2014
- 851
Hello all,
Iam thinking about putting some casters on the bottom of my Lincoln Tombstone stick welder, to move it around the shop easier.
The bottom of the welder has two steel feet welded to the frame - upon which the welder sits when in use.
I wonder if these feet also act as a ground for the machine? If so, if I raise the welder off the ground 3" or so, with rubber casters, would I also need to somehow attach a grounding cable to the machine?
Thanks
Glenn
Thanks
Glenn
