- Dec 31, 2010
- 937
Apparently I successfully sharpened a 4 flute end mill today. The sharpening was done on a Enco Tool and Cutter sharpener that came from an estate sale. The machine has multiple adjustment capabilities as the shaft holding a grinding stones on each end can be rotated horizontally and vertically. With the motor mounted on the spindle frame it can be raised and lowered vertically as well. Two tailstock assemblies were among the accessories: one is an indexing R-8 tool holder that held the subject 1/2" 4 flute HSS double end mill. An attempt at sharpening was made earlier but the mill did not perform well. This time after re-reading Harold Hall's" book again, the center was ground prior to grinding each flute at approximately 15` to develop a concave center and the relief angle was 15` also.
The end mill was tested by trueing up the adjustable plunger bar for a rotary indexer that I am trying to make utilizing a 40 to 1 worm gear that was surplussed by the cement plant I retired from. The bar came out smooth and true.
The reliability of the end mill will determine if I did in- fact get the job done close to correctly. This has been one of the learning challenges encountered while making the indexer. There are other mills in my tool box but this was a task (skill) I need to learn.
Have a good day
Ray
Have a good day
Ray
