- Jan 2, 2011
- 331
Sorry if this is the wrong place to post this.. only section I could find pertaining to motors.
I have a Westinghouse 3/4 HP motor on my lathe. I had it apart to redo the wiring and decided to look at the bearings. It has a single row ball bearing type on each end. It is sealed on the armature side, but the outer side is open and slides into a round pocket a little wider than the width of the bearing . On the outside on each end cover of the motor is a single screw in plug with a channel angled toward the round pocket. Even If I did pump grease into the hole, there would be nowhere for the pressure to go, and might pop out the seal. When I filled the pocket with grease and pushed the end cover on the motor, grease was forced out of the open hole.. maybe this was the right procedure?
OR..
I am wondering if I am suppose to use some kind of oil instead of grease?? Seems oil would leak out.. any thoughts?
Another interesting note.. when the motor is mounted, the plugs are facing downward.
OR..
