  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
lathe collet question
3
Like what you see?
10
BGHansen
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Nov 23, 2014
726
Likes
1,617
#2
I'm happy with my 5-C collects from CDCOtools.com. I have a 1/16"-1 1/8" set by 64ths and a second one in 32nds. No problems with any of them.
Problem with 5-C collects is they don't have a large clamping range. Many guys here have instead gone with ER (extended range) collets.
Bruce
T Bredehoft
Dec 27, 2014
2,141
Likes
1,480
#4
ER40 collet chucks may not be thick on the ground, I waited two years before a I found one with a MT2 taper.(they weren't available) Neither were there chucks to mount on a face plate. They've started to turn up, hope you can find one. They are limited to 40 millimeters through. (one inch.) Since getting the taper mounted chuck, it's been on my lathe almost continuously.
richl
Active Member
Mar 2, 2013
706
Likes
474
#5
Another option for purchasing or building a er40 chuck, you can purchase collet blocks hex and square and use them either the hex in your 3 jaw (my chuck is a bisson set tru) or the 4 sided in your 4 jaw chuck. You can adjust the runout to near zero. They can also be used in the mill... not an idea everyone will want, but it gets you up and using er40 collets at a low buy in number till you can get together a true chuck.
Hth
Rich
RJSakowski
Feb 1, 2015
2,769
Likes
2,840
#7
Tom, I believe you meant 25mm, not 40mm for the ER40 maximum capacity
T Bredehoft
Dec 27, 2014
2,141
Likes
1,480
#8
Right you are, RJ, my calculator, TRS, bought in 1997 is giving me fits. 40 X .02927 gave me 1.006. WRONG.
mksj
Jun 12, 2014
1,451
Likes
1,636
#10
There are pros and cons for each system, that have been discussed in previous posts. I mostly use 5C similar to what Bruce mentioned, I know a few people who have purchased the CDCO 5C collet set and for the price they are very good. Unfortunately the 5C has a very limited clamping range, and even with a 1/64th set some pieces are hard to hold. Today I needed to hold some hubs with a 0.200 diameter x 0.250" long which was between two 5C collet sizes, had to go with the larger size and clamp down on the collet, and it barely held. You also get some distortion from over clamping because 5C only clamp at the tip. ER collets clamp from both sides along the length of the collet. But this is also a downside of using ER collets, they are made to clamp along the full length of the collet. Try to clamp a small piece like 1/2" in the collet and it will distort, let alone 0.250". I made my own ER40 set-tru chuck for the lathe, I use it for odd size longer stock and also it has less axial runout then my 5C chuck which is also a set-tru. You can also buy a 5C collet to ER40 chuck, but you are sometimes compounding the runout error.
https://www.ebay.com/itm/New-5C-Col...R40-Collet-chuck-holder-USA-SELL/162682518669
I mostly use 5C, it works and is quicker in my opinion then the ER40. I do a lot of repetitive turning steps, so the hubs shown below may have six different turning steps in/out of the collet and the maximum holding length is very short. Just would be very time consuming flipping wrenches out at each step with the ER chuck and you would need a spacer in the back of the ER collet so it wouldn't collapse. Wouldn't work for me because I use a through the collet stop system to set the depth. The tolerance on the hubs is 0.001". If you do go with an ER chuck for turning, I would recommend a 1/32nd collet set, the 1 mm increment sets get a bit wonkie at the clamping extremes. An ER bearing nuts helps a bit to reduce the TIR and make torquing the collets easier, but I already had one fail clamping down on a collet. Last but not least is the dismal state of the chucks available. There are generic asian direct bolt on D1-4 5C chucks and D1-4 ER40 chucks. I tried two direct mount generic 5c chucks and they had terrible TIR, like 0.006", and the ER40 chuck was also as bad, they were all returned. I currently run a Bison set-tru 5C, and previously had the Lathemaster version which was a nice chuck but seems to be no longer available. If you do get a generic 5C chuck, I would recommend a plain back, cutting the register a little bigger in the back plate and use the tap method to center it. Otherwise consider the Bison/TMX or possible Gator 5C chucks.
http://www.hobby-machinist.com/threads/what-kind-of-collet-chuck-should-i-make.59514/#post-490404
http://www.hobby-machinist.com/threads/do-i-need-a-collet-chuck.49453/page-2#post-448788
http://www.hobby-machinist.com/threads/5c-collets-good-ones-vs-bad-ones.18010/#post-442225
Jimsehr
Active Member
Apr 23, 2013
300
Likes
243
#11
One thing to think about is 5c setup lets you use square and hex collets ,soft collets you can bore to size and over size collets and ID collets that you can use to hold parts on their bores. I also have a metric set of 5c collets. And you can move a 5c collet to the mill or drill press in a spindex or indexing fixture. And if you get the lever style 5c collet you can load parts with the machine running. A big time saver if you have lots of parts to do.
RJSakowski
Feb 1, 2015
2,769
Likes
2,840
#12
Another advantage of the 5C collet chuck is the relatively unobtrusive nose of the chuck which allows you more freedom to work close to the collet.
Edit: Looking at the size of an ER40 collet nut, the difference is minimal though.
outsider347
Active Member
Sep 3, 2012
254
Likes
11
#13
Thanks for the suggestions Gents.
Moving up from my old C Man lathe to this PM 1236 is proving to be a new adventure for sure
Obvious (to me) question.... Is there a MT 5(spindle bore size) collet set available???
tks
ed
mksj
Jun 12, 2014
1,451
Likes
1,636
#14
There are MT5 to 5C (Grizzly P4026001 - COLLET ADAPTER ) and MT5 to ER40 chucks, which would need a draw bar/tube to mount. Problem is that it is very close to the headstock and also you are more limited as to the size stock that can be passed through.
http://zlivecenter.com/MT5ER40S23
Bob Korves
Jul 2, 2014
4,032
Likes
4,183
#15
I am using the shop made hand wheel 5C collet closer I recently finished:
http://www.hobby-machinist.com/threads/hand-wheel-collet-closer-build.62278/
It uses the Grizzly P4026001 MT5 to 5C adapter. That adapter is not particularly cheap ($100+) and not really accurate either (mine came with .0006" runout, and that seems to be pretty typical.) I have partially reground the adapter with my tool post grinder, using a wheel with a flexy 1/8" shank, which was hopelessly slow, and now it is at .0004" runout until I can get a 3/4" wheel to fit my 1/4" arbor, then maybe I can make some real progress.
I have room for up to 1 1/8" stock to go through my 1 1/2" spindle bore with the drawbar in place, which is more than the 1" maximum 5C collet capacity, so it should work for most anything I would want to do in a collet.
I mostly use even Imperial sizes of stock and fasteners when working with the collets, so I do not expect that to be a problem. I will get a few emergency collets to use for odd sizes.
Yes, the drawbar collet setup gets the carriage close to the headstock, but I do not see that as much of a problem. The QCTP and tooling reaches to the collet easily. The only real issue for me is that I will need to make a different arrangement for measuring carriage travel than the mag back indicator on the ways I am now using.
I only have about $125 in the entire hand wheel drawbar setup, and some metal I had laying around and the 5C collet set I have for other tasks as well. It seems to work just fine and should meet my needs for collet holding on my 13x40.
outsider347
Active Member
Sep 3, 2012
254
Likes
11
#16
After a bit of searching here, I like the 5 C style Lathemaster chuck that runout can be adjusted out....unfortunately no longer available.
Anyone happen to know if this style chuck is available elsewhere
[6]
5 [7]
