- Feb 2, 2013
- 3,538
when we marinate at home, generally it stays pretty much on the outside of the cut of meat.
the vacuum tumbler is used in the meat industry to vacuum impregnate meats with marinades.
the process is very quick.
in a couple hours under vacuum, the marinate actually gets inside the product.
it works fantastically well.
there are many different manufacturers of these machines.
i get to work on some real doosies sometimes, this week has been no contradiction to that.
i had a customer who wanted a Lance LT30 Vacuum Tumbler & Marinator, to be brought back from the dead.
they had a couple "technicians"(read:hacks) make feeble attempts at repair to the poor beast.
but their attempts were in vain.
3 others failed , before i was to succeed:
the previous saboteurs didn't really have much luck in repairing the poor old unit.
when i showed up to see the wretch, it was really a mess.
it's supposed to:
1: draw a vacuum
2: have motor speed control, forward and reverse
3: the tumbler must have a jog function, forward and reverse
4: tumbler must also have a continuous push button run function
5: the tumbler must have optical safety interrupt
6: vacuum pump must be push button for continuous operation
it did none of these things upon arrival, so i gave them the bad news that it was coming with me. after a haggle over the expense, the owner wished to restore only part of the machine's capabilities.
i don't like leaving things undone but if the guy says he doesn't want or need it, i wont give it!
the vacuum pump was MIA, the controls were disconnected, jumped,spliced, and taped together in a mess that would make spaghetti jealous.
rather than try to fix stupid, i gutted the entire control, DC motor control system and optical safety system and designed one of my liking.
i removed every control component and piece of wire and started at square 1.
i first ran the DC control circuit, i used a KBMM 125 DC controller for the lesson 1/2 hp DC motor that turns the tumbler chamber.
i installed a new vacuum pump and plumbed and wired it in.
then ran all the individual wires to 4 control relays, 4 momentary control switches, 2 maintained contact control switches, potentiometer, & 2 optical safety switches.
a closer look at the completed retrofit
here is a video of the machine during the operational test
here is some product, 4 tri tip's vacuum tumbled/marinated @23"Hg- for 30 minutes!
as always thanks for reading, watching, and commenting!
it's supposed to:
1: draw a vacuum
