4
Keep Your Fingers Clear of the Angle Grinder (Warning - Pic Included)
3
Like what you see?
10
HBilly1022
Active Member
Active Member
Dec 22, 2015
395
Likes
597
#1
This happened a few months ago while I was doing some precision grinding with my angle grinder. When it happened I felt it right away but still had the grinder running and couldn't drop it. I had to shut it off and put it down safely, instead of throwing it aside. Then quickly go and clean all the crap out before the pain started. I contemplated going to see the doc but opted not to. I was concerned that it might not heal well since there was a bit of flesh missing and the white thing in the cut looked like it might be a nerve that could end up healing itself to the skin and that might be a long term issue with sensitivity. In the end it turned out fine although there is some sensitivity when it gets cold.
papa-roe
Sep 15, 2017
38
Likes
64
#2
Woooo doggies! That is an impressive wound. My luck, I would have grabbed a rag to wrap it just as I realize that it is soaked with paint thinner. I can't like the picture but I thank you for the warning.
markba633csi
Active Member
Active Member
Apr 30, 2015
1,318
Likes
526
#4
Welcome to the club :cupcake: ouch ouch ouch
ps I had my angle grinder lose the wheel which then ran across the yard- away from me fortunately
Mark
Suzuki4evr
Active Member
Active Member
Sep 29, 2017
78
Likes
39
#7
Lost one finger allready in motorcycle accident (caused by car driver), don't want to lose another, but happens to all of us.Welcome to the club.I think the white part is the tip of the bone. Good luck. Just watch out for infection.
NortonDommi
Active Member
Active Member
Nov 15, 2016
122
Likes
69
#8
Occupational hazzard for some, personally I never use an angle grinder without leather gloves on, my preference is good quality Riggers gloves and I buy on the small side then break in the same way the Army taught with boots which is soak in water over night then rub Vasoline into hands and pull on gloves and wear till dry. Planned gardening is good for the drying as the gloves get stretched every which way and end up a perfect fit.
GarageGuy
Active Member
Nov 9, 2013
789
Likes
226
#9
I've been bitten a couple of times by angle grinders. Now I wear leather gloves whenever I use one. Whenever it bites the leather glove, I smile and know it would have hurt without them. Same thing on my power wire brush wheels. They don't dig as deep, but they hurt just as bad. I buy the cheap Harbor Freight leather work gloves, so there are 10 pair laying around the shop wherever I might need them.
Glad there was no long term damage.
GG
Superburban
Active Member
Active Member
Jan 2, 2016
301
Likes
244
#10
Been there, done that. It always seems to happen when you are in a hurry. When I picked up my drill press, I cut open the package that the tiedowns were in, and got myself real bad in the hand. Just wrapped a rag around it, and kept working. After we were on the highway heading home, I aske the wife to clean it for me, Man was she pissed. It was big enough that it should have had stiches, but I had a good five hour drive ahead of me, so a cleaning, and clean rag, and duct tape was all it got. Still has a fair scar, but a lot better then I thought it would turn out.
Life goes on.
HBilly1022
Active Member
Active Member
Dec 22, 2015
395
Likes
597
#11
Your going to like this ............. I was wearing leather gloves. Went right through them. Guess it could have been worse if I didn't have them on.
kvt
Active Member
Oct 21, 2014
1,654
Likes
725
#12
Problem is it is not always the fingers. Wait till you get hit in the midsection by a chunk of the disk. Found those guards do not really stop things. And cotton shirts do not stop things either. Now have a leather appron to wear
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,296
Likes
3,495
#13
ouch!
i have been shocked, burned, smashed, pinched, poked, and filleted at one time or another by all the equipment i work on.
i had a grinder incident, with a 7" HD angle grinder-
i was grinding a bit above knee level on a steel firebox for an industrial tar kettle.
i was replacing a 12" diameter x 10' heater tube and had to grind out the old welds after cutting with the Oxy/acetylene rig.
all was good until i got too far into the bore of the firebox and the grinder kicked back, hitting me on the inside of my thigh, mid thigh.
it cleared a 3"x 1/2" wide channel immediately in my leg , luckily it was mostly superficial, it went down about 1/4".
the funniest thing is that it didn't bleed much, the wound was basically cauterized by the grinding wheel.
the doctor picked carborundum out of the wound for 45 minutes before sewing me back up with 2 layers of stitches .
Good Times!
i'm glad that you didn't get it worse. take it easy!
chicks love scars :grin:
kwilliam
Steel
Registered Member
Sep 25, 2014
25
Likes
15
#14
And how easy is it to go through the cord?
Especially when you have a few things lined up to cut through.
Just one careless swing and everything changes.
6
5 7
