    Dismiss Notice
Just Unpacked My G0704 Mill...
Discussion in 'DOALL SAWS' started by GBrackett, Jul 31, 2016.
Tags:
  1. GBrackett
    GBrackett United States H-M Supporter - Premium Content H-M Supporter-Premium
    9
    3
    Hialeah, Florida
    City:
    Hialeah
    State:
    Florida
    -Return to Top-
    Got this in Friday. Now to clean it up, and then learn about setting it up so I can use it. Looking forward to learning about it on this site!
    brino likes this.
  2. GBrackett
    9
    3
    Hialeah, Florida
    City:
    Hialeah
    State:
    Florida
    -Return to Top-
    I few of the items I got to go with my G0704. There are three more boxes of things to figure out which I still have to open.
    Sandia likes this.
  3. dave2176
    dave2176 United States Active User Active Member
    152
    43
    City:
    Bountiful
    State:
    Utah
    -Return to Top-
    Congratulations. That's a nice machine. Enjoy.
    GBrackett likes this.
  4. kizmit99
    kizmit99 United States Active User Active Member
    51
    28
    City:
    Ellicott City
    State:
    Maryland
    -Return to Top-
    I predict you'll be happy with your purchase. I bought the same machine a few years ago.
    Just a couple of quick suggestions...
    First, be sure to secure it to floor if you're able to. I found the machine to be quite "tippy" until I bolted it to the concrete floor in my shop.
    Second, I see you got a vise with a swivel base... You'll probably want to use the vise without the base most of the time. A couple of inches in Z, and the extra rigidity are more than offset the hassle with remounting it if you ever need to rotate the vise (I've not used mine once in 3 years)...
    If you can swing it, the powered X-axis kit that Grizzly sells saves a lot of hand-cranking.
    I just recently built a mist-cooler for mine - best upgrade ever! I'm now routinely taking cuts that are twice as heavy as I was taking previously and the cutter stays cold and sharper longer (chips are hot, but the cutter and the workpiece stay cool).
    brino likes this.
  5. GBrackett
    9
    3
    Hialeah, Florida
    City:
    Hialeah
    State:
    Florida
    -Return to Top-
    I got a deal on the vice with the rotary base for the same price as the one without it. I'm adding about 75 lbs of weight to the base as my floors are plywood covered with fire rated cement board, fire resistant mastic and tile over that. Hopefully that will help with any stabilisation issues. I have about a 100 lbs available if needed that will fit in the base cabinet.
    Is there a post here that shows what a mist-cooler is. I didn't get the power unit as I plan once I learn to use the mill manually to convert it to CNC.
    In my past life I was a techie, programmer type of guy. I have used different CAD and Drafting software to design parts for projects. Never run any of the equipment. My main uses will be for knife guards and butt caps. As time passes I'll move on to pocket knives.
    The vise I got was a 4" I'm hoping it's not too big. I'm also looking at a 2" toy maker vice for smaller work but, I'm not sure if I need it.
    Thank you for your advise!
  6. kizmit99
    51
    28
    City:
    Ellicott City
    State:
    Maryland
    -Return to Top-
    Here's a link to a thread on one mist cooler setup: http://www.hobby-machinist.com/threads/zero-fog-mister.27394/#post-241476
    I used a whole house water filter canister as a coolant reservoir on mine instead of a propane tank. I also used a pre-made $7 sprayer head instead making one from scratch. I have about $50 total invested in it. Here are a couple of pics:
    PS: the 4 inch vise is a good size for this mill.
  7. markba633csi
    markba633csi United States Active Member Active Member
    142
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    That's a neat mister you made but I don't quite understand: is that water mist? Doesn't that cause major rust issues?
    Inquiring minds want to know..
    Mark S.
  8. GBrackett
    9
    3
    Hialeah, Florida
    City:
    Hialeah
    State:
    Florida
    -Return to Top-
    Kizmit99, Thank You. I will try this as soon as I get the mill broken in. I plan on doing that tomorrow. I'll look for a water filter when I go out in the morning. I'll pick up a up a nozzle while I'm out together with the lubricant that mixes with water. I also will get a length of hose for the drain plug.
    Again Thank You!
  9. markba633csi
    142
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Oh I see, it's a mixture, not just water
    never mind LOL
    MS
  10. dlane
    dlane Active User H-M Supporter-Premium
    499
    83
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    Mix 2x what it says per water, less rust
  11. kizmit99
    51
    28
    City:
    Ellicott City
    State:
    Maryland
    -Return to Top-
    In that pic I was still waiting to get the actual coolant, so it was just water (but that was only for a very brief time). Now I'm using KoolMist 77 as the coolant. It's mixes with water at something like a 1:32 ratio (one part koolmist, 32 parts water). Supposedly it will not go rancid and shouldn't lead to rust on the equipment. I've been using it for about 2 months now and no signs of any rust. I've also only used about 6oz total of the mixed coolant (the reservoir is down about an inch and a half). It's hard to imagine it given the temps right now, but come winter I plan on adding a shot of antifreeze to the mix to (hopefully) keep if from freezing up in the unheated shop.
Share This Page
