    Dismiss Notice
Joel Miller Cnc Milling Machine
Discussion in 'CONVERTING A MACHINE TO CNC' started by Nels, Apr 24, 2016.
  1. Nels
    Nels United States Founder Staff Member H-M Supporter-Premium
    788
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    Original at http://jmillerid.com/wordpress/category/cnc-milling-machine/
    CNC mill phase 1: planning
    Thursday, 9 June 2011
    While I have understood the basics concept of CNC machining–and have utilized it in my work–I never fully appreciated how complex a system a CNC machine is until I set about designing and building one. There are many software and hardware layers are involved in the process, and each of these layers offers nearly endless options to choose from… CAM software, controller software, steppers vs. servos and their torque specs, power supplies, motor controllers, breakout boards, encoders, etc. not to mention the mechanical modifications to the manual mill.
    So as a first step in converting my milling machine to CNC I looked at a lot of other people’s conversions with this and similar machines, especially in the copious posts on CNCzone.com and specifically the great work that “Hoss” has done. In the interest of not re-inventing the wheel (for now) I chose one of Hoss’s recommended stepper motor configurations from Keling, and bought his plans for the mechanical conversion from a manual to a motor-driven G0704 mill.
    From there I started to sketch out a system map, detailing the wire-for-wire connections between the different components to best understand how this might go together. This also helped me to think through the available options, like physical interface elements such as emergency stop buttons and limit switches.
    The lower area will exist in the base of the machine and will include the higher voltage DC elements that actually drive the stepper motors. A KL-600-48 power supply provides 48V to the three KL-5056D motor drivers. Control signals from the PC come through a C-10 breakout board, which serves to isolate the PC from the motor drivers. It seems that keeping things separate like this is good practice and tends to avoid funky interference or crosstalk problems with the PC.
    The upper area represents a “controller box” which will hang off the side of the machine, and will enclose a small form factor PC, a 15″ touchscreen monitor (eBay!), a ruggedized keyboard, and a small cluster of buttons and indicators. The I/Os will include a main power cord, a ‘switched’ power cord to feed the lower cabinet, a DB25 to connect the PC’s parallel port to the breakout board in the lower cabinet, a DB15 to connect other signal to the breakout board, a series of connections for limit switches, three relay connections to control the mill’s spindle and two different coolant systems, and USB and ethernet ports to communicate with the PC.
    A main switch on the front panel controls the power to the entire system– PC, monitor, and the motor power supply in the lower cabinet. “PC power” and “PC reset” switches are connected directly to a header on the motherboard, as are LEDs to indicate power and hard drive activity. A USB port on the front panel is intended to be the main method of getting files on the PC, as I intend to use a pared-down Windows installation with a bare minimum of extras (like network access).
    The remainder of the controls are dedicated to the safety system, which is based roughly on a scheme provided in the Mach 3 documentation but adapted to work with an Arduino microcontroller. The first part of the scheme monitors the emergency stop button and limit switches (what they call the “interface”) to make sure the machine and operator are OK. The second part, called a charge pump circuit, reads a 12.5kHz signal that the controller software produces when everything is functioning normally. These functions are monitored on I/O pins of the Arduino, and if either condition reports a problem the Arduino cuts power to the lower cabinet and the milling machine’s spindle (via relays) and lights the appropriate indicator(s) on the front panel. After a limit switch or e-stop event, the “interface reset” button will give the controller software the all-clear and resume power.
    The “motion override” button is one that I threw for my own comfort. Say I’m running a program and it comes to a point where I need to change to a different sized end mill before continuing. The program would stop the spindle and pause and wait for me to go in there with my bare hands to switch out the tool. At this point I’m relying solely on software to keep the machine from firing up the spindle and plunging the razor sharp end mill through my hand and into the table (for example). Not that this is likely, but I don’t trust software… after all, robots will kill you. So the “motion override” button tells the Arduino to cut power to the spindle and controller until I press the button again. I know what you’re going to say… the Arduino that’s in control is also running software. Well, Arduino is benevolent and would never try to hurt me.
    With the system laid out and all the components chosen, the next step is modeling it up in CAD.
    Tags: CNC, G0704, milling
    Posted in CNC milling machine | Comments Off
    CNC mill phase 2: CAD
    Tuesday, 23 August 2011
    With the system map complete and the major components sourced I set about the mechanical design of the enclosures. I originally intended to design and build a custom enclosure for the computer and drivers, out of brushed aluminum/stainless, etc. but came to my senses. Sometimes you have to recognize when to go all out, and when to just get it done. So in that spirit I found a suitable electrical pull box from Automation Direct and probably saved myself a month of fabrication and finishing time. That’s not to say this box will work as-is off the shelf, so there’s still plenty of opportunities to fabricate and modify.
    6073043473_7f3c5a1622.jpg This is the main two-part enclosure after the extensive modification required to mount the PC and monitor, keyboard and PCBs. Since the enclosure is steel I opted to weld as much of it together as possible in the interest of simplicity. Most of the front panel is cut away for the monitor and keyboard, so the ribs that are welded in also add rigidity. A continuous steel hinge is welded to the front panel and then bolted to the enclosure to join them together.
    The touchscreen monitor will mount to the ribs on three sides, allowing the PC components to attach to the VESA mounting holes on the monitor through a simple, flat aluminum bracket. The keyboard will be sandwiched against the inside of the front panel with a flat steel plate.
    The interface elements on the right side of the front panel are connected to a large PC board that includes the Arduino and charge pump circuitry. A smaller board isolates the relays, most of which will be switching AC power.
    The original concept was to pack everything into the controller box so it would be a standalone assembly, but I came to understand the risk of packaging higher DC voltage components (like stepper drivers) into the same box as sensitive logic-level components (like a PC). So the motor drivers and their power supply moved into the base of the milling machine, mounted to a welded steel assembly that will mount into the base through an opening cut through the back. The pink datum planes in the screenshots represent the interior space available in the upper half of the machine’s base, which is pretty much consumed by the electronics.
    Next up is the PCB design for the interface board in the controller box…
    Tags: CAD, CNC, G0704, milling
    Posted in CNC milling machine | 2 Comments »
    CNC mill phase 3: PCB design
    Wednesday, 24 August 2011
    In my CNC controller design most everything is handled by the PC and the off-the-shelf breakout board and motor controllers. But there is an ‘optional’ hardware layer that provides a measure of safety–both for the user and the machine–and a degree of feedback as to the status of the system. This is where a couple of custom PCBs come in.
    The design of this subsystem is based off a sample from the excellent Mach 3 controller software documentation (without permission to reproduce it, see page 4-24 of this pdf document). Essentially the system monitors a series of limit switches–designed to prevent the machine from trying to move beyond its mechanical limits in any axis–and one or more E-stop buttons, which together are called the ‘interface’. It also listens for a 12.5kHz electrical signal that the Mach 3 software generates when it is running normally, and if any of these conditions are abnormal the power is cut to the stepper motors and the machine’s spindle. The Mach 3 example does this in an analog way with a clever series of relays, and includes LED indicators and a reset button to provide system feedback to the user.
    I realized that a microcontroller could do the same job and offer some more flexibility, and ultimately be simpler. At the heart of this board is a standalone Arduino–basically an ATMEGA 328 and a small handful of discreet components. The IC just to the right of that is a MAX232 chip for serial communication with the PC. This is certainly not necessary, but I figured I have a PC in the same enclosure, so why not enable it to connect directly to the Arduino, either for reprogramming purposes or for some future physical computing need related to the CNC mill. To the right of that is an HEF4538 monostable multivibrator IC and the rest of the ‘charge pump’ circuit provided by Geckodrive’s Mariss Freimanis, which turns the 12.5kHz signal from Mach 3 into a logic high or low into the Arduino. To the upper left is a simple 12VDC (from the PC power supply) to 5VDC power supply, for the ICs and the C-10 breakout board in the lower cabinet. This 5V and GND and the rest of the lines between the Arduino and C-10 board connect to a pin header, shown directly below the Arduino.
    On the very far right is where the E-stop and limit switches will connect to an Arduino I/O pin, and a pull-down resistor to keep the pin from floating. The E-stop and limit switches are connected in series and set up in a ‘normally closed’ configuration. This is an added measure of safety as an inadvertently severed wire will indicate a fault, rather than fail to indicate a real problem should one arise. As configured here, a normal condition will read as ‘high’ on the I/O pin.
    On the upper right is a series of switches and indicators: MACH OK and INTERFACE OK indicators, INTERFACE RESET and MOTION OVERRIDE buttons (each with their own indicators), and a PC POWER button with power and HD activity LED and a PC RESET button. The latter are not connected to the Arduino at all but go directly to the PC motherboard.
    6073526221_22b47d993b.jpg The reason the other buttons and LEDs are part of the PCB is that I had a handful of Klockner-Moeller illuminated switches. Except that they are not actual switches and they are not illuminated; rather they are the actuatorin a larger assembly that includes switches and lamps. Being real industrial controls, these full assemblies are extremely expensive. Also, I am dealing with signal-level voltages and currents and don’t need anything heavy-duty. So I designed my board to sit just under these switch actuators and provided a couple of small tact switches that are depressed when the big button is pressed. In the middle of each set of switches is two LEDs that will fire up through the middle and illuminate the button.
    On the lower right and directly above the Arduino are two headers that connect to the relay board. This is where the AC power terminal block is, and where the relays that switch AC power reside. The first three relays are for switching the main power to the lower cabinet and AC power to two different (future) coolant systems. The other two relays replace the original power switch on the mill (it is a DPDT switch) so the controller box will now have control of the mill’s spindle.
    Since my PC board far exceeds the maximum size that the free version of CadSoft Eagle allows, I designed the Arduino board in two halves and joined them together in Illustrator. The large cutout for the E-stop button provided a nice natural break between the two halves. The upper half was also too big, so I designed it with much less vertical space between buttons and simply stretched the image out later.
    Note: if these images look very slightly skewed to the left, you don’t need to check your eyes. My laser printer warps the transparency film as it’s going through the hot printer, so double-sided PCB artwork doesn’t line up when flipped to face each other. So I printed two copies of a square grid and flipped them face-to-face, then measured the offset so I could compensate for it. Now as a last step before printing transparencies, I skew the entire page in Illustrator horizontally by -.179 degrees, and I end up pretty close every time.
    Here’s the relay board, and a small daughter board for the USB connector on the front panel.
    Next step: PCB fabrication!
    CNC mill phase 4: PCB fabrication
    By now I’ve got a pretty good system down for fabricating PC boards:
    1. print artwork onto transparencies
    2. laminate the dry film resist onto copper
    3. expose the board on the UV light box
    4. develop the film, rinse
    5. etch the PCB in a tupperware in a sink full of warm water (I’ve been experimenting with acid cupric chloride, but my go-to is still ferric chloride), rinse
    6. strip the film off with acetone & tin plate the board with Tinnit (also in container in warm water), rinse with ammonia solution
    7. drill & trim board
    8. dab on solder paste and place components
    9. reflow solder in the toaster oven
    10. hand-solder through hole components
    This is basically the process I followed this time, but this was the biggest PC board I’ve made to date at around 11″ long. To start with, I couldn’t fit the whole thing on a 8-1/2 x 11″ transparency out of my laser printer, so I had to print it in two pieces and tape them together.
    I also couldn’t fit the board in my typical etching tray, so I had to use our good Pyrex baking tray for the etching and plating. Otherwise the process went smoothly. I intentionally sized the board to just fit into my reflow toaster oven, and despite using expired solder paste the boards came out pretty good.
    Tags: CNC, Eagle, G0704, milling
    controller box mounting arm
    Tuesday, 30 August 2011
    I don’t usually build as I go, without detailed planning or at least some sketches. But one Saturday a few weeks ago I had several hours to myself and I was itching to make some physical progress on the CNC conversion, so I took a quick inventory of my metal stock pile and just started building.
    6097298493_eba2a6ec9a.jpg The mounting arm for the CNC controller box–that physically attaches the box to the mill–is a very simple part with well-defined parameters. The controller box has four mounting holes on the back side and the column of the mill is a thick iron casting that can be drilled & tapped basically anywhere. I knew approximately where I wanted the box to be, so it was a simple connect-the-dots part design. I had a 2′ length of square steel tube and some angle iron, so I started chopping it up and dry-fit it to the back of the controller box.
    I MIG welded it together (still practicing that welding… getting better) and cleaned it up, then primed it with some Rustoleum, then did a quick test fit on the mill.
    A couple of coats of black lacquer and it’s good to go!
    Tags: CNC, milling, PCB fabrication, welding
    CNC mill – metal fabrication
    Monday, 12 September 2011
    With the CAD design more or less complete it’s time to make some parts. I generated some 2D views of the various parts and plotted them at full scale, then spray-mounted them to some sheet metal, most of which I had cut to size beforehand.
    As a result, most of the fabrication involved simply drilling and tapping the right sized holes in the steel:
    But some of the more complicated parts required cutting out larger areas of material. I did most of this very slowly with the jig saw and a metal-cutting blade. But some of the rectangular areas allowed me to use the mill!
    I quickly realized that this machine will be challenged by steel, as even this thin material caused the whole column/head to flex as I cranked on the wheels. I think it will be possible to machine steel, but the feeds will need to be very slow and it will definitely require copious amounts of coolant.
    Here’s the “lower cabinet assembly”–the part that will house the motor drivers and their power supply–welded up and primed:
    The front panel of the controller box required extensive modification, done entirely with the jig saw and drill bits (the large holes were made with a step drill). I couldn’t wait to dry-fit the assembly onto the mounting arm:
    The front panel also required a fair amount of welded parts on the back side, for mounting the monitor and keyboard. Notice how the thin sheet metal warped after welding:
    Final fitting before priming and painting:
    Next step, assembly…
    Tags: CNC, milling, welding
    CNC controller – assembly & wiring
    Assembly of the controller box has gone very well. The PC components (motherboard, hard drive and power supply) all mount to the monitor’s VESA holes through a flat aluminum bracket, and the monitor attaches right to the front panel. The keyboard gets sandwiched between a flat steel plate and the front panel, with some minor modifications to its silicone cover to make it fit.
    The rest of the assembly revolves mainly around the PCBs and front panel controls. Before mounting the PCB assembly I installed the small USB daughter board that provides a USB port on the front panel.
    The rest of the assembly mounts over this, aligning the tact switches to the button actuators. The remainder of effort went into managing the many wires neatly into the cabinet.
    The lower cabinet assembly was much more straightforward:
    Of course I wanted to fire it up as soon as possible, even though nothing was connected. The Arduino IC was not yet programmed so none of the UI elements were working, but I was able to transfer files through the USB port.
    This is far from complete, but I’m ready to start integrating the Mach3 software with the electronics and make sure they can talk to each other.
    Tags: arduino, CNC, G0704, milling
    Mach3 setup
    I’d love to say that getting the CNC controller software (Mach3) to talk to my stepper motors went quickly and flawlessly. It didn’t, but to be fair there are several hardware steps between the two and I don’t blame Mach3. Anyway by the end of the day I had gotten to this point:
    Next step is mechanically attaching the motors to the mill, then addressing the whole Arduino safety system.
    CNC mill parts
    Sunday, 2 October 2011
    Tonight I finally finished the metal parts for the CNC conversion. These were made from a subset of the “phase 1″ plans I purchased, and are all the custom parts I need to attach my stepper motors to the G0704 mill.
    Most of these were pretty straightforward. The standoff-looking parts are steel rod, parted off to length and then drilled and tapped. The fatter bushing-looking things are aluminum, also round rod that was drilled out then trimmed to length. The big flat aluminum parts were a little more challenging, requiring some milling, but the holes were all center-punched and drilled on the drill press (I still don’t trust positioning on the mill due to the backlash in the screws).
    This cylindrical steel part took several hours. Starting from a 1.5″ steel rod, I first turned the skinny stem part, then flipped it around to bore out the inside. The tricky part was getting the piece clamped into the lathe so it was perfectly concentric to the shaft I already turned. Apparently my three-jaw chuck is not perfectly centered, so I used the four-jaw chuck and aligned the part manually using a dial indicator attached to the cross slide. According to the indicator I got within half a thou for concentricity… good enough!
    Once it was centered I bored out the inside and put the little shoulder on the end. Next it was drilled and tapped (for set screws), then off to the mill to make the flats on the shaft.
    The most challenging part was probably this aluminum bearing block, shown here in the four jaw chuck. Again, concentricity here is key, so a lot of time was spent getting this guy aligned when I flipped it around.
    Technically I’m ready to mount the motors to the mill, but I’m hesitant to start the process. I’ve gotten used to having a milling machine available, and once I take the handwheels off it’ll be out of commission until the CNC conversion is complete and working! Here we go…
    Tags: CNC, G0704, lathe, milling, shop
    first CNC movements
    Thursday, 12 January 2012
    Manual entry of G-code, with a Sharpie mounted in the drill chuck…
    [flickr video=6487457455]
    milling machine modifications, part __?
    Friday, 13 January 2012
    In this minor modification I added a 50 lb. gas spring between the column and the head, meant to assist the Z-axis motor in lifting the weight of the head.
    The stock part is a 50 lb. gas spring with ball-joint fittings, McMaster part #4138T621. I simply drilled a hole in the column (and tapped it for 5/16-18) for the lower pivot, but the upper pivot point wanted to be above the top of the head to allow for a full 12″ of travel. I designed and machined a simple aluminum part to extend the upper pivot point and mounted it to the head. While I was at it I also machined a nice little cap to cover the hole where the Z-axis crank was.
    The backlash in the lead screws has been giving me relatively poor surface finishes, so I bead blasted these parts to even them out. I like the look, but the “toothy” surface really grabs onto dirt.
    I was hoping to double the rapid speed I could get out of the Z-axis, but I didn’t quite make it… It went from 15 in/min to about 25 in/min, although I just bought some better way oil so we’ll see if that makes up the difference.
    Tags: aluminum, CNC, milling, shop
    CNC milled PC board
    Monday, 16 January 2012
    One of my goals for the CNC mill has been to help fabricate PC boards, primarily in terms of cutting out the overall shape and drilling any through holes. For simple boards, however, it is possible to machine the circuit traces into the copper and avoid the entire photo-etching process altogether. I recently had a chance to try this process out, and the results were quite good.
    This particular board needed to be circular, and needed to have a rectangular opening for a switch, so CNC routing the outline is really the way to go. The circuit is relatively simple, so it also lends itself well to routing the traces. If I were to etch this circuit the usual way with photoresist, developer, etchant, etc. etc. it would have taken three times as long.
    The board was designed in Eagle as usual, but I then used an add-on to Eagle called PCB-gcode to generate gcode from the traces. There are a number of settings to specify depths, tool settings, speeds, etc. but it is fairly self-explanatory.
    I chose some pretty basic settings, which resulted in the following preview:
    I was never able to figure out how to generate the outlines using PCB-gcode, so I re-drew them in Mastercam and went from there. PCB-gcode is supposed to have that ability but there appear to be some bugs in the software that limit its ability to deal with circles and arcs. If anyone has made better progress than me I’d love to hear about it.
    6710510339_fbe4ff1d5c_b.jpg Anyway the final product came out pretty good. I was pretty pleased with myself having tightened up the backlash to only .004″ per axis, but after machining .024″ wide traces I realized how bad that is. Under the right circumstances this is a good technique to save time, but I wouldn’t try to machine extremely fine traces or tight-pitched pads until I work those last few thousandths of backlash out of my machine.
    [flickr video=6710516711]
    Tags: CNC, Eagle, milling, PCB fabrication
    Posted in CNC milling machine, electronics | Comments Off
    CNC surface machining
    Monday, 23 January 2012
    I’ll be posting more about exactly what this part is in the near future, but for now I’m super excited about making my first surfaced part on the mill…
    This is ABS, which I’m using to test the program before moving on to brass. Good thing too, because one of the last commands jammed the end mill down into the part… I pressed the reset button just as the bottom of the collet was carving out a pocket in the ABS and nothing was damaged, but if I was using brass things would have been ugly.
    The end mill is a 1/4″ three flute uncoated carbide ball end mill. The spindle speed was around 2400 rpm and the feed was 7.5 ipm.
    Tags: CNC, G0704, milling, shop
    home made chuck key
    Tuesday, 31 January 2012
    This weekend I spent a lot of time in the shop machining parts for my CNC mill, and ran into a problem with the lathe. The four jaw chuck has these adjustment screws to move the jaws in and out, but I can’t find the chuck key needed to adjust them. They use an inverted key–it’s and innie, not an outie, like most chuck keys–and it’s almost impossible to adjust without that particular tool.
    I had a leftover piece of steel rod, so I made my own:
    The ends were machined on the mill, clamping the piece upright in the vise. The shoulder was turned on the lathe (in the three jaw chuck!).
    I milled a socket into the other end for a 3/8″ ratchet, although the fat body makes it easy to turn quickly by hand. (I tried to knurl the end but I still don’t know how to knurl properly, so I just mucked it all up)
    Operational!
    Tags: aluminum, CNC, G0704, lathe, milling
    Posted in CNC milling machine, lathe | 1 Comment »
    the importance of sketching
    Thursday, 12 April 2012
    I’ve often talked to students, young designers, and colleagues about the importance of sketching as a part of the design process, whatever flavor of design that might be. I like to think that I practice what I preach, but sometimes I forget.
    I have been struggling with the design of an enclosure for my CNC mill that would allow me to use flood coolant and contain the mess of metal and plastic chips this machine can create. I had a rough idea in my head, and looked around at existing enclosures, so I immediately jumped into CAD to sort out the design. For days I iterated on-screen, unhappy with the results but trudging through each new concept until I hit a wall.
    So last night as I sat on the couch I opened up my laptop to give it another go, only to find technical issues that kept me from launching my CAD software. Frustrated, I shut the laptop and pulled out my sketchbook. Within minutes I was teasing out the solutions that were so elusive on screen, and by the time I shut off the lights I had my design roughed out.
    So, one more time, especially so I remember: Never underestimate the importance of sketching. CAD is an invaluable tool, as are rendering packages and Illustrator and Photoshop, etc. But for quick ideation, brainstorming, breaking through a mental block, or simply communicating with your fellow designer/engineer/marketing person, nothing beats sketching.
    Thanks for humoring me. And stay tuned for my next rant, titled mock it up before you fock it up
    Tags: CNC, milling, sketching
    Posted in CNC milling machine | 16 Comments »
    CNC mill oiling system – concepts
    Monday, 25 June 2012
    As I’m preparing to dismantle the milling machine for its major ball screw overhaul, I’m thinking about what else I want to do while it’s apart. One thing that most commercial machines have is a semi-automated way of oiling the sliding parts of the machine. Like most of the awesome mods that can be done to this particular mill, Hoss has already figured it out, so I’ll base much of what I do on his existing work.
    The biggest component of this project involves modifying the saddle in such a way that it can deliver oil to each of the four X and Y-axis ways. A series of tubes (shown in blue below) deliver oil into holes drilled into the saddle (shown in red), which in turn come up in the middle of each way. The surface of the ways are then milled with a shallow “S” curve groove to distribute the oil across the surface. Additionally, the saddle holds the ball nut mounts so it can conveniently distribute a squirt of oil to each of the ball screws as well.
    The Z axis ways will be oiled from the head, so it will have its own plumbing. But the two assemblies will have to meet on the column via some flexible tubing, then connect to the oil pump and reservoir.
    I have some thoughts on implementing my oiling system in a more compact way than Hoss. There are a lot of tight spaces in which this will operate, and other things I may want to integrate into the same real estate like limit switches, way covers, scales, etc. Furthermore I feel that clear plastic tubes are useful for seeing that oil is present in the system but they seem a little too flexible for my taste, probably requiring that they be tacked down periodically to prevent them getting in the way. I’m thinking about using rigid copper or aluminum tubes that are bent into position, which seems to be the way most commercial machines do it.
    oiling_2-300x164.jpg I took a look at McMaster’s selection of fittings and decided they are too bulky for my application, and probably way overkill for the relatively low pressures my system will see (up to 7 psi). I started thinking about how small a fitting could get, and figured that soldered connections are about the best you can do. The trouble with fully soldering all the connections is that the plumbing becomes permanent to the machine, which is probably bad. So then I thought maybe the plumbing could all be soldered into a semi-flexible assembly that is then pressed onto fittings in the saddle (see the above sketch).
    These fittings were starting to look a little fussy to machine, and in a high vibration environment like a milling machine I don’t like the idea of friction alone making a pressure connection (albeit a low-pressure one).
    oiling_31-1005x1024.jpg So next I thought about a hollow screw solution that would also serve to attach the fitting to the saddle. There would need to be a nice soft seal (like an o-ring) that could compress enough to allow aligning the hole in the screw (shown in green) to the hole in the sleeve (medium blue). Then I realized that if the screw had a shoulder that reasonably sealed to the inside of the sleeve, it could also serve as a flow control valve– useful for getting the flow consistent between the varying oiling points. The idea can also be adapted to a tee configuration, where there is free flow past the junction:
    So I was feeling pretty good about myself when a coworker pointed out that I had basically re-invented a banjo fitting, which is a low-profile, high-pressure connection commonly used in brake lines. A banjo fitting has a donut-shaped reservoir around the bolt, designed to provide free flow at any orientation. So my design provides the flow adjustment that a banjo fitting intentionally avoids, which is a useful feature in my low-pressure system.
    Oh well. I realized a long time ago that coming up with something that has already been invented is just means you’re on the right track.
    CNC mill to-do list
    Monday, 14 January 2013
    Making progress (finally) on the mill upgrades, including full enclosure, flood coolant, oiling system, and ball screw conversion. Stay tuned!
    Tags: CNC, milling, shop, sketching
    DIY tube-bending tool
    Saturday, 19 January 2013
    My plans for the milling machine oiling system call for some small-diameter bent brass tubing. I looked into the various tools designed for this, but the high end is too expensive and the low end looks pretty cheesy. I also wanted a small bend radius, which is hard to come by in off the shelf tools. It seemed easy enough to design a simple bending tool, and besides there’s nothing I like better than making stuff that makes other stuff.
    My tubing has a 3/16″ OD and I was aiming for a 3/8″ bend radius (to the centerline of the tubing). I only anticipate needing 90 degree bends, but it didn’t seem any harder to allow for 180 degree bends. With these parameters I modeled up a simple design in CAD and ordered a few pieces of brass and steel from onlinemetals.
    The first step was to grind a lathe tool blank to a 3/16″ diameter half-round shape. With this I turned some 3/4″ brass round rod into a set of rollers that closely fit the 3/16″ tubing.
    I then milled the end of a 4″ length of 9/16″ square brass bar to accept the smaller roller, and drilled it for a tight fit to a 1/4″ dowel pin (1″ long).
    I then drilled two 12″ lengths of 1/8″ x 3/4″ mild steel to accept the two rollers and welded two more shorter lengths of steel to create a rectangular tube handle. Done and done!
    The square brass bar is clamped into the vise, and the tube to be bent is gently clamped to the brass bar with a rubber-jawed clamp. The first test worked perfectly!
    The bends aren’t perfect– there’s a small amount of collapsing, probably from the small bend radius and the imperfect roller profiles. But I sawed through one of the bends at the thinnest part to see how much collapsing there was, and I think it’s acceptable for my needs.
    Here is the collapsed section (top) next to the normal tube section for comparison. Not bad!
    Next step: experiments in brass soldering.
    Tags: brass, milling, tools, welding
    Posted in CNC milling machine | 15 Comments »
    CNC mill oiling system – plumbing
    Monday, 25 March 2013
    This is it… Grizzly Miller is in several large pieces on my bench, and the major upgrades have begun. First up, oiling system.
    I made some refinements to the original concept and even built a tube-bending tool for the small brass tube I’ll be using.
    First step was machining the X and Y axis ways on the mill’s cross slide. I used a simple ‘S’ curve, programmed point-by-point into an old ProtoTRAK-converted Bridgeport. On the same machine I pocketed out some clearance for the X-axis ball nut.
    Beyond these sketches, most of the design work happened on-the-fly. This is unusual for me, but I don’t have CAD data of the original milling machine parts, and tube fabrication turns out to be more sculpture than engineering anyway. I also bought a silver solder kit specifically meant for joining copper alloys, and tried a small test piece from some scrap material.
    I then fabricated the main brass manifold and mounted it to the cross slide. From there it was a matter of drilling end points in the cross slide and connecting the dots with brass tubing. Each of the four ways are connected with my modified banjo fitting, which allows for flow control adjustments. The two ball nut mounts were modified to accept an oiling tube, which will simply splash each ball screw with oil. The manifold will be fed by a flexible tube, which will attach to the little stub coming off the manifold.
    The soldering process is messy and dangerous, but once the parts are cleaned up they’re really quite beautiful.
    The finished cross-slide assembly:
    2013-03-24-16.53.04-1024x768.jpg 2013-03-24-16.52.42-1024x768.jpg 2013-03-24-16.52.50-1024x768.jpg
    The Z-axis got a similar treatment:
    More to come, stay tuned!
    booker, 4gsr, cjtoombs and 1 other person like this.
  2. rdhem2
    rdhem2 United States Active User Active Member
    25
    28
    Great Pacific Northwest
    City:
    Yakima
    State:
    Washington
    -Return to Top-
    Great write up. Enjoyed the whole meal deal. Electronics to oiling. What a spread! This is a great site!
  3. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,389
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    For small fittings, I recommend checking out Beswick. Very small precision fittings, which would make designing a lube system so much easier.
  4. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,311
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    You are a looney, the kind that I like however (-:
    For the time and money expended making that mill go in circles you probably could have bought a clapped out Haas TM1 and be ahead of the game for PCB work.
    The lube system is a work of art.
  5. brino
    brino Active User H-M Supporter-Premium
    2,223
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    Test
    OK, account works. :)
  6. Tony Wells
    19,389
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    I just wish I had the spare time to do a project like that. I wouldn't, but I wish I had that much time! :)
Share This Page
