    Dismiss Notice
Jet-16 T-Slot?
Discussion in 'JET LATHES, MILLS, SAWS, ETC.' started by chrism, Mar 11, 2014.
  1. chrism
    chrism United States Active Member Active Member
    0
    6
    City:
    Aptos
    State:
    California
    -Return to Top-
    What size clamping kit should I get for a Jet-16 Mill/Drill? Thanks for any help in advance!
    :dunno:
  2. tertiaryjim
    tertiaryjim Active User H-M Supporter-Premium
    210
    43
    City:
    Naturita
    State:
    Colorado
    -Return to Top-
    I've got a jet 16. It uses the 1/2" studs and t-nuts.
    My mill-drill also had metric feed screws which were close to 8tpi but not the same and the nut adjustment was horrible.
    Had to replace all of it.
    I'm machining new keys and plan to scrape the ways as the machine marks are clear in the dovetails.
    Ulma Doctor likes this.
  3. Vegemitesandwich
    Vegemitesandwich United States H-M Supporter - Premium Content H-M Supporter-Premium
    7
    8
    Humble, TX
    City:
    Humble
    State:
    Texas
    -Return to Top-
    It's metric 14mm slot with a 20mm T. I bought a Chinese 5/8" set from LMS still had to file/grind the Ts to fit the slots
  4. tertiaryjim
    210
    43
    City:
    Naturita
    State:
    Colorado
    -Return to Top-
    You are so right. I did a quick check and the slots are about 0.570"wide so 14mm would fit well.
    Thanks for the correction.
  5. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,348
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    My mill drill also has 14mm slots. I'm using a 5/8" kit & just milled down the T-nuts. You can find 14mm or 9/16" clamping kits but they cost more cause they're not as common.
    Not sure if it matters to you but I went with 5/8" cause I wanted 1/2" studs. If you get a 1/2" kit (undersized but will work) it uses 3/8" studs.
Share This Page
