    Dismiss Notice
Jacob keyless chuck
Discussion in 'MACHINE ACCESSORIES (Tables, Vises, Indexers)' started by Flyrod, Jul 14, 2017.
  1. Flyrod
    Flyrod United States Active Member Active Member
    26
    18
    City:
    Miami
    State:
    Florida
    -Return to Top-
    Hi All - I have a very old, NOS chuck, Jacob's 100CR (for center rest) keyless chuck
    this is from the 70's or early 80s (when they were discontinued)
    it has never been used and was left in the wide open position, where it is stuck
    i am assuming the grease has turned to varnish?
    what is the best thing to soak it in? - i tried mineral spirits, but it won't budge
    not knowing exactly how the mechanism is or what is inside, i am hesitant
    thanks!
    PS: looks like this
  2. Splat
    Splat Active User H-M Supporter-Premium
    90
    48
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    I love Kroil or PB Blaster.
    DHarris likes this.
  3. Dave Paine
    Dave Paine United States Active Member Active Member
    143
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    Another vote for Kroil. I have used Kroil to loosen many rusted fasteners and stuck items in hand plane restorations.
    You have to get Kroil from the manufacturer, Kano Labs.
    DHarris likes this.
  4. projectnut
    projectnut United States Active Member Active Member
    24
    18
    City:
    Madison
    State:
    Wisconsin
    -Return to Top-
  5. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    723
    113
    Neither here nor there
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    Kerosene might do the trick. Toss it in for a good soak and forget about it for a couple of weeks, then pull it out and see if you've made any progress.
    Kroil, as mentioned above, is very good also. Well worth the trouble to get hold of some.
    One product that is often overlooked, and I just love, is K&W Knock'er Loose. It is available at NAPA stores as well as some others such as O'Reilley's. I once had a frozen kingpin on an old Ford pickup with the twin I beam suspension. This stuff actually freed it up, making the job much easier than pressing out the old one and replacing it!
  6. Splat
    90
    48
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    You can get it from McMaster or Amazon.
  7. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,393
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Kroil is good stuff. A 50:50 mixture of ATF and acetone is probably the most effective penetrant, and one of the cheapest. Just mix some up, and keep it where the acetone will not evaporate. Be careful with it, acetone is toxic.
  8. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,302
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I love Kroil as well but I wouldn't use it in this case for soaking a drill chuck. If the grease has expired, proper way is to disassemble the chuck to clean & relube. Soaking in something is just temporary fix.
    Edit: misread, well I suppose if it's stuck, you'd have to get it free before being able to rebuild it. :)
    Way cheaper to get it directly from Kano, anywhere else marks it up. They have a standing offer where you order a can of Kroil & can choose another one of their products to try for free. On my last order I choose Microil for the free product. It's instrument oil & it's great stuff too.
    4gsr and Bob Korves like this.
  9. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,103
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    That chuck is also referred to as a 'commutator' chuck. It holds the end of the shaft dead true while you skim cut the commutator. I think you that, bu for others that have never been around one. One thing to keep in mind, the jaws may not go down to a small diameter of a shaft. May only have a range of 3/4 down to 3/8 diameter. Not positive on that.
    I would prefer to soak it in mineral spirits, once freed, lubricate with some light oil. I like Will's free deal, forget about mine!
  10. kd4gij
    kd4gij United States Active User Active Member
    1,072
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    woochucker likes this.
  11. kd4gij
    1,072
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
Share This Page
