I have only a lathe very heavy duty lathe, i've seen couple pictures of lathe milling attachment but don't know is this a useful tool, can i get any accuracy with this attachment ?
I have a very small lathe, atlas 10" and I had a milling attachment I used quite a few times until I got my mill. On a larger lathe a milling attachment would be even more useful.
My lathe has some wear, i don't need to do lots of milling, i'll need it most for cutting key ways or milling short slots, will it break milling cutters because of the wear?
When I had room only for a Taig lathe in military housing over seas, the milling attachment was all I had room for and I used it. A dedicated mill works much better if space and finances are available.
i had a milling attachment for my 10" atlas.
my attachment was useful for relatively small work.
a worthy amendment to the arsenal if you don't already have a milling machine
+1 on Savarin's work, he does top notch work with his set up.
we'd all be proud to have done what he has accomplished.
