Thank you the references. I spoke to the seller and was able to get a better deal based on them. I'll happily pass along at cost plus shipping to anyone here wanting a set (except for the two sets I need/want). Here's what will be available (Underlined are spoken for) at 80 per set of 8 cutters plus shipping which will likely flat rate around 10 bucks I would think. Oh, I'm picking these up this weekend and will take pictures:
Involute gear cutters, HSS - Diametral pitch: 8
- 14 1/2 degrees
- #1-8
- Diameter: 2 3/4" - Hole size: 1"
Involute gear cutters, HSS - Diametral pitch: 9
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 10
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 11
- 14 1/2 degrees
- #1-8
- Diameter: 2 5/8" - Hole size: 1"
Involute gear cutters, HSS - Diametral pitch: 12
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 14
- 14 1/2 degrees
- #1-8
- Diameter: 2 1/2" - Hole size: 1"
Herk
Involute gear cutters, HSS - Diametral pitch: 16
- 14 1/2 degrees
- #1-8
KEEPING
Involute gear cutters, HSS - Diametral pitch: 18
- 14 1/2 degrees
- #1-8
- Diameter: 2 3/8" - Hole size: 1"
4gsr
Involute gear cutters, HSS - Diametral pitch: 20
- 14 1/2 degrees
- #1-8
KEEPING
Involute gear cutters, HSS - Diametral pitch: 22
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 24
- 14 1/2 degrees
- #1-8
- Diameter: 2 1/4" - Hole size: 1"
DavelnMi
