Involute gear cutter set, if you could only have one
i got a picture of these from the seller. They have the usual laser engraved designators such as DP 20 14 1/2 No 1 ...and then the most unsavory word of them all: "CHINA"
That took the wind out of my sails as I try my hardest for avoid china anything. I'll probably still get one full set, so I can cut my lathe change gears should I ever break a tooth.
If anyone wants a set let me know and I can buy up more and pass them along.
If he has 10 DP 14 1/2 , ill take a set.
Thank you the references. I spoke to the seller and was able to get a better deal based on them. I'll happily pass along at cost plus shipping to anyone here wanting a set (except for the two sets I need/want). Here's what will be available (Underlined are spoken for) at 80 per set of 8 cutters plus shipping which will likely flat rate around 10 bucks I would think. Oh, I'm picking these up this weekend and will take pictures:
Involute gear cutters, HSS - Diametral pitch: 8
- 14 1/2 degrees
- #1-8
- Diameter: 2 3/4" - Hole size: 1"
Involute gear cutters, HSS - Diametral pitch: 9
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 10
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 11
- 14 1/2 degrees
- #1-8
- Diameter: 2 5/8" - Hole size: 1"
Involute gear cutters, HSS - Diametral pitch: 12
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 14
- 14 1/2 degrees
- #1-8
- Diameter: 2 1/2" - Hole size: 1"
Herk
Involute gear cutters, HSS - Diametral pitch: 16
- 14 1/2 degrees
- #1-8
KEEPING
Involute gear cutters, HSS - Diametral pitch: 18
- 14 1/2 degrees
- #1-8
- Diameter: 2 3/8" - Hole size: 1"
4gsr
Involute gear cutters, HSS - Diametral pitch: 20
- 14 1/2 degrees
- #1-8
KEEPING
Involute gear cutters, HSS - Diametral pitch: 22
- 14 1/2 degrees
- #1-8
Involute gear cutters, HSS - Diametral pitch: 24
- 14 1/2 degrees
- #1-8
- Diameter: 2 1/4" - Hole size: 1"
DavelnMi
I'd be interested in this set provided the price is right.
- 14 1/2 degrees
- #1-8
Oops, I see the price.
Do you accept Paypal?
Ken
paypal is fine with me, just send "family & friends" and there's no fee taken that way. I'll mark the DP18 and DP24 as spoken for. I will also let you know when I actually pick them up, so no need to send payment yet.
Seller also sent me a pic of one set. Has the keyway...I've seen some without which is a bit curious. I guess that could be one way to make them cheaper
I don't have a paypal account nor do I want to deal with them. Any other options?
