    Dismiss Notice
inverted v templates
Discussion in 'MACHINE RESTORATION & WAY SCRAPING' started by expressline99, Jun 3, 2017.
  1. expressline99
    expressline99 H-M Supporter - Premium Content H-M Supporter-Premium
    104
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    OK great I will see if I can get a 6"
    Paul
  2. astjp2
    astjp2 United States Active User Active Member
    77
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    A 12" . 0005 per foot level is plenty accurate and precise enough to level your plate. Without a good foundation isolation pad, your concrete floor will move the plate more than that.
  3. expressline99
    104
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    I ordered the Shars 8" .0005 level. I am picking up 2" .120 square tubing to build my stand Monday. At least with the level and a 3 point support system I should be able to check it occasionally and fix any movement that happens. I've got to do the same with my lathe once I have the chip pan done....and the mill also. I hope to scrape both in but I will need some large squares also to get that done. After I make the straight edges. If I got done this year with one machine I'd be happy. :)
    Paul
    Dabbler likes this.
  4. Dresden
    Dresden United States Iron Registered Member
    5
    3
    City:
    St Paul
    -Return to Top-
    We used to call this a Gasoline overhaul, clean, flake, paint
    Bob Korves and 4gsr like this.
  5. ziptie
    ziptie United States Swarf Registered Member
    3
    3
    City:
    Madison
    State:
    New Jersey
    -Return to Top-
    You can do a lot using the tailstock base, a precision level and an indicator.
    Bob Korves likes this.
  6. expressline99
    104
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Just out of total curiosity what is a foundation isolation pad? I don't have that I've got a 43+ year old concrete floor that isn't level. :)
  7. expressline99
    104
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    I can tell you the logan and the bridgeport didn't get any kind of overhaul. :) the BP was a total mess and still going. But until you guys told me about it I wouldn't have guessed people did this.
  8. expressline99
    104
    43
    City:
    Reno
    State:
    Nevada
    -Return to Top-
    Getting closer everyday. The replacement level is here(first one was broken in shipping) and I got an indicator base that is adjustable enough to get where I need it...I think.
Share This Page
