- Feb 7, 2012
- 539
I got a pair of new DRO's from David to put on my RF31. The last ones had some issues [mostly due to my negligence] and I wanted to start fresh. Things went fairly well - since most of the layout work had been done with the prior install. Anyhow, long story short - after getting everything somewhat finished [for today] I ran a quick check on returning to zero and accuracy at 4" L & R on X axis. Just preliminary checks for now to see if it was worth the effort to do over. IT WAS. Much better accuracy and return to zero - no jumping of numbers, etc. as the last ones I had put on. Again - mostly my fault - not blaming the Igaging units at all on this. So - for those who may have an RF mill/drill, these pics may come in handy. Just sharing my experience , good and bad. )
The white catch material came from a print shop - it's a hard pliable plastic material that folds with a slight cut but stays intact. Oil/solvent resistant - good stuff. I drilled and tapped holes for mounting 10/32 screws to the brackets, and set them in parallel between table and lower mount - within .005 all the way across. Same on the Y axis.
I made the X axis shield out of an old florescent light lens cover, and attached it with silicone rubber caulk. The Y shield is made from the plastic material for now until I devise a better plan. I managed to remove the clearance issues from the first go round, and got everything much more in line and in close tolerance. No bending, bowing, or rubbing is apparent so far......
OK Last but not least - the dirty RF31 as it sits in the shop. I know it's small - but it get's the job done for my most of my hobby needs.
