- Jan 28, 2011
- 3,480
Years ago I bought a King drill press, as my Dad's was too small for some of the things I was up to. His is just a hand drill mounted in a accessory press. Both B&D.
I was not satisfied with the large run out of my drill press and looked it over to see what I could do. Basically there is not much that can be done in my case internally. In further looking I saw that the anti-rotation screw on the left side had an effect. If tightened it helped but it was grabby and stiff. So I decided to add 2 more rubbing surfaces on the right and front face. As the pictures clearly show, they are simply 2 brass set screws. Drill and tap and install the screws, and with a bit of playing around with the 3 screws I was able to reduce the run out to near zero. The chuck has issues but that was for another time.
Pierre
Pierre
