old or used does not = inaccurate, why do so many of use covet the old machines and then quiver at the of a used/old indicator? If the indicator is questionable, then you can get it checked by a qualified repair facility. Unless the unit is so old you cannot repair it, it will be just fine for the majority of users. I work in a production shop and we tend to hold .001 or greater. The only time we hold a tighter tolerance is when we bore a hole for a bushing and then its only .0003+- so the practicality of what is necessary is on the operator/designer/engineer, and what is your design criteria/application require such a tight tolerance? Think about this.....do you need to have a .001 tolerance for a bracket to hold a keyboard for a computer:nuts:? We have these types of tolerances at work for the most unusual things because the engineers who did not think about the application. Just some food for thought. Tim
