- Nov 24, 2017
- 64
Hi Everyone,
I just thought I'd look into the problem with the free play with my longitude slide wheel. (Atlas V42 10F)
I had about 1/4 turn of free play and it seemed like the little gears were just engaged by the end of the teeth.
After investigating how to get apron off I realised I needed to remove the lead screw.
I figured what have I got to loose so out it came and sure enough the apron came off after removing just the two Philips head screws on the top.
The amount of crap behind the apron was amazing but I managed to clean it up OK and at least I know what magic goes on behind there now.
Unfortunately I found a multitude of problems.
The Gear Case (10F-11) has been smashed and there is a fudge up of home made bits holding it together.
Strangely when I refitted it just the way it was most of the free play is now gone.
Unfortunately there is a bronze bevel gear with a missing tooth that is part of the cross slide power feed.
It is a bit hard to read my parts list but it looks like a 341-05p (not sure if that is a p or 9 on the end)
The cross feed was working but I think it just jumps the missing tooth by a hair.
Removing the lead screw from the feed reversing gear box meant that I needed to pull that apart as well before I could refit the lead screw.
I found a similar amount of crap hidden in there. I managed to clean that out as well but the Yoke (9-59) has also been smashed and a fudged up welded thing has taken it's place. The feed lever has a had a couple of new v notches carved in the case which I guess is due to the welded up yoke not being the correct size but the little pin doesn't hold the lever in place. It pops out of gear after a minute or two which will pretty much stop me from ever doing any screw cutting unless I figure out how to fix it. It appears that the little key in between the reversing gear and the lead screw can slide along the shaft and snag on the bevel gear which may be where I'm feeling some of the crunchiness. It is really hard to tell what is going on in that little reversing box and behind the apron once it is assembled.
Just to top it off while re-assembling the lead screw it appears that the two lock nuts on the opposite end have been stripped. They just spin around and never tighten or come off.
With the screw and gears all reassembled it is just a bit crunchy. I'd hoped it would be nice and smooth now that it is all clean. I removed the change gears from the end of the lathe leaving a large 128 tooth gear attached directly to the lead screw. I can spin it around but I'm really not happy with the way it feels.
I think I have kicked a hornets nest and am concerned if I'll be able to get it back into working shape now.
Any hints and advice appreciated.
Thanks
David
Thanks
David
