Re: Ideas for Scroungers - More ideas
Old appliances that no longer work can be a wealth of certain materials. For instance, a washer, dryer, fridge, freezer or stove can yield large panels of "enameled" steel that can be used for very weather resistant signage and other things. Two sides of a stove, carefully cut, put together with some wooden spacers and framed with some salvaged stainless channel stock served as my business sign for over 20 years of Northeastern winters. But you don't have to tear these finds apart to make use of them. For instance, an upright freezer or fridge can make a great dry, air-tight storage box, complete with shelves for storing things that you don't want to be exposed to moisture or oily air. A stove with a dead cooktop can be used as a tempering oven if it still works, and the racks and other pieces can also be salvaged. The stovetop "spiders" can be used as hotpads or trivets on you bench. Discarded exercise equipment can have a lot of tubing, as well as pulleys, shafts, and weights. Dishwashers, Washers and dryers, in addition to a couple square yards of salvageable enameled steel, can also give up motors, pulleys, belts, relays, and all sorts of other pieces. We once used an old dryer as a tumbler to soften the edges of wooden blocks for children's pull toys. Just throw in the blocks and some random pieces of sandpaper and let'er rumble. It is amazing what you can find on the edge of the road or in old barns. We once slavaged two old milkhouse pumps, added motors (which we acquired from the rubble of a mill fire) and had one compressor and one vacuum pump. And they were interchangeable! Low volume, but the tanks held either pressure and vacuum for what we needed. Old computers have small fans and electrical switches and cords that are useful. I once salvaged the gears and belts out of a "self-scooping" cat litter box. Don't think it was all that icky, it was new, but damaged in shipment. When I ordered the replacement, they told me to keep the old one. Here's a real find - drill chucks and gears from old, no-longer functional drills, corded or cordless. I have salvaged several small chucks, up to 3/8 capacity, attached to their precision shafts, which I can use as small drill or reamer holders for hand work or in my drill press, as a sort of "poor-man's quick-change" tooling. I also got some interesting bevel gears, reversing switches, bearings and other pieces as well.You gotta' think outside, and inside the box, and sometimes use the box too. My wife thinks I'm a packrat, but never ceases to be amazed when I rummage around in my junk box and come up with the right piece to fix something that would have had to be replaced otherwise.
