    Dismiss Notice
I think I have a parting problem........
Discussion in 'GENERAL DISCUSSIONS' started by sanddan, Mar 19, 2017.
  1. sanddan
    sanddan Active User H-M Supporter-Premium
    552
    93
    City:
    Damascus
    State:
    Oregon
    -Return to Top-
    I think I have a real problem with parting on the lathe. When I got my fist lathe I bought a HHS parting blade and installed it into the holder that came with my QCTP. I started with a thinner parting blade, around .087" thick I think, and watched a bunch of video's before attempting to actually part off a piece on the lathe. It went ok for the first several attempts but then BAM! The tool jammed in the cut and busted about a third of the blade off and left a chunk buried in the part.
    WOW, that got my attention. It was some mystery steel I had for practice so at least I didn't ruin anything important and I wasn't hurt so back to watching video's looking for the cause of my misfortune. I thought, maybe I should get a thicker blade, less likely to break maybe?
    Some time goes by (where I avoided the parting tool like a bad dream) and then I needed to make some aluminum washers for a project so I had to break out the parting tool again. No avoiding this time.
    You might see this coming based on the title. Apparently 2 hp can quite easily break a 1/8" parting blade.
    Bummer.
    More video's later I decided I needed one of the blade style tools that uses carbide inserts. I got a nice setup from Shars and about the third time I tried it BAM. Actually it broke without the drama that the solid HHS blades displayed, but ruined one of the two ends. This is starting to get expensive.
    So I went back to avoiding the parting tool and used the bandsaw instead. I thought my problem might be flexing of the blade so when I saw a cool looking setup that looked very heavy duty I spent more $$ hoping for parting success.
    I had to make some plastic washers so thought it was a good time to try out the new tool. After aligning the tool I made several washers without issue (keep in mind this is plastic now) and thought, maybe this is the answer.
    Then I had to make a 1" OD by .100" thick washer with a 1/2" hole in steel. Shouldn't be too bad right? You might see where this is going about now. More carnage.
    I think I will go back to the HHS blades as they are a lot cheaper. Ruining a very expensive tool is starting to get old about now.
  2. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,433
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    If you are doing everything right and are still breaking tools, then something has to be flexing a lot.
    On the other hand, this is the only parting tool I own. It hangs where I can get to it easy.
    ch2co, BGHansen, 4gsr and 3 others like this.
  3. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,034
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    Are you doing this dry?
  4. sanddan
    552
    93
    City:
    Damascus
    State:
    Oregon
    -Return to Top-
    Wet, cutting fluid for steel and WD-40 for aluminum.
    I'll try a hacksaw next. LOL
    Tough to make thin washers with that I'll bet.
    4gsr and JimDawson like this.
  5. firestopper
    firestopper H-M Supporter - Premium Content H-M Supporter-Premium
    1,217
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Dan,
    Are you hand feeding? What RPM are you turning? last question, is the insert clamp tight on the Kennametal?
  6. ronboult
    ronboult Australia Active User Active Member
    34
    28
    City:
    Macleay Is, Brisbane
    -Return to Top-
    Hi Dan
    I feel your pain.I went through the same process starting with HSS blade then GTN2 and GTN3 bits in blade holders with similar results. Making relief cuts to stop binding helped a bit. However I think GTN bits are very short which does not help to stabilize the bit in the holder
    I finally changed to MEGHR1616-2 holders with Korloy MGMN200-G H01 or NC3020 Inserts. What a difference!
    Day before yesterday I was parting 15mm deep (the limit of these holders into 54mm dial steel with no problems. I used the uncoated H01 inserts and they cut the steel like cheese. 460rpm and just hand feed. Didn't seem to matter how fast or slow I fed the cutter the cut just proceeded with no drama. I did take the precaution of making sure the blade was exactly square to the cut, dead on centre and made a clearance cut after entering about 10mm. I'm totally convinced!!!!! I suppose there is a chance with my luck that next time will not go so easily but from my current observations I dont think so.
    As mentioned above the only problem with MEGHR1616-2 holders is they are limited to about 30mm diam rod.
    Have just ordered some MEGHR1616-3 holders to try and looking for a holder with greater depth of cut. Both holders and Korloy inserts are available on AliExpress very cheap
    The next photo compares the inserts. Note the jump in size between MGMN200-G and MGMN300-G and how short the GTN inserts are. I think the MGMN300-G inserts will be much more robust. I haven't received my MEGHR1616-3 holders yet but I am hoping they will have a greater depth of cut.
    Top - MGMN200-G NC3020
    Next -MGMN200-G H01
    Next - MGMN300-G NC3020
    last GTN2 Unknown grade.
    Don't give up you will get there
    Ron
    BGHansen likes this.
  7. savarin
    savarin Active User H-M Supporter-Premium
    1,289
    113
    City:
    Townsville
    -Return to Top-
    Owning a flexi 9x20 I went through the same woes as your self.
    I have cured my problems with parting to the point where I just sling the tool on and go.
    A couple of things I had to do to get there.
    1, a thin brown paper shim under the axa tool post so it wouldnt turn around the post.
    2, tighten the cross slide gibbs. Holding my finger on the join between the cross slide and saddle I could feel the two separate when cutting. A new brass gibb strip cured this.
    3, watching the considerable flex in the tool post when parting I decided to remove the compound replacing it with a solid plinth. I now only replace the compound to cut small tapers.
    4, use a continuous supply of cutting fluid to the tip of the parting tool.
    The combination of all these has allowed me to part with no worries and to the point where I dont even have to ensure the tool is EXACTLY at 90 degrees to the job.
    I've parted a couple of stainless and mild steel parts with a slight cone/curve. (I dont advocate this but it does do it if I'm not exact and works)
    With the continuous supply of fluid the swarf just peels out in long tight curls.
    I forgot to add I only use high speed steel parting blades.
  8. Silverbullet
    Silverbullet Active Member Active Member
    353
    83
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    Most if not all small LATHES will never part off a piece of metal. My reason for saying this they lack the strength to keep the parting blade from flexing. First the tool rest moves , compound flexes , the cross slide moves the ways even torque over. If you ever expect to part you will need the tool blocked up from the ways with a roller bearing to support the blades movement up to the point of just touching the piece to be cut . Rigid as possible no flexing at all then the blade still will flex and may break. I'm in the design stage of making a rotating saw blade mounted to the tool post , like a grinder , only mounted in a qctp with air fitting . My thinking with the lathe turning and blade turning no flex of any amount should make much difference. I'm letting the cat out of the bag but I'm sure it works.
  9. JimDawson
    3,433
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    For that I have a friend named McMaster-Carr :grin:
    BGHansen, mikey and Bamban like this.
  10. woochucker
    woochucker United States Active Member Active Member
    102
    43
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
    I am not sure I agree. My small south bend lathe does very well at parting. Admittedly it was learning how to properly part. My problem was being a fraction too low, thinking it would cut better. I learned after a few mistakes that being low was bad , being low often caused a disaster since the piece would lift and all hell would break loose. Being high by a small amount was acceptable until it stopped cutting, it would not lift.
    Being dead on, would be best. But there might still be a lift danger .. So being high by about .0005 might not be a bad thing. Being dead on, I still worry .. Being low.. never.
    brino and ronboult like this.
  11. mikey
    mikey Active User H-M Supporter-Premium
    1,276
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    With all due respect, I have to disagree, Silverbullet. I have an Emco 11" lathe that parts everything I turn with a HSS P-type blade or an Aloris GTN3 inserted carbide blade. My little Sherline can part anything that will fit in the lathe using a P1-N blade mounted upside down in a rear mounted parting tool post. In fact, the Sherline will part mild steel at 1200-1500 rpm and will cut 303 stainless washers 0.010" thick without any issues at all.
    A sharp blade mounted perpendicular to the work with the tip at center height will part easily on most lathes, small or big. I think the biggest problem for most guys is that what they think is center height is not really center height; a bit high and it won't cut; a bit low and it digs in a snaps the blade. A positive feed is also important.
    British Steel, DHarris and Bob Korves like this.
  12. jbolt
    jbolt United States Active User H-M Supporter-Premium
    710
    93
    City:
    Mountain View
    State:
    California
    -Return to Top-
    You should have no trouble parting with your PM-1340GT. What RPM are you parting at? Are you using the power feed? Most problems I see people having are not on center and running the speed/feed too slow.
    Assuming the tool is set at the correct height and is square to the part. Keep the tool length to the minimum required to make the cut and try and keep the tool stick out to max 2x the blade height. For the HSS try 0.003 to 0.004 feed at 100 SFM. For the insert tool try using the power feed at 0.004 to 0.005 at 100 to 200 SFM. Remember your cross feed is 1/2 the chart setting. Parting needs lots of fluid. I use kerosene for aluminum and dark cutting oil for steel, constantly and generously applied with a small brush or squirt bottle.
    Also keep the compound slide retracted and locked. I usually also lock the carriage.
    Bamban likes this.
  13. sanddan
    552
    93
    City:
    Damascus
    State:
    Oregon
    -Return to Top-
    This last time was at 240 rpm and I've only tried hand feeding. The clamp on the Kennametal was tight. After the fact, when I was re-aligning the tool post as it had moved slightly, I noticed that the compound wasn't locked. That might have been the cause.
    Bamban likes this.
  14. firestopper
    1,217
    93
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    Yea, I didn't want to ask basic questions as I know your on it. Rigidness is your friend for this operation. The RPMs are fine even a little higher is ok, but the tool post should be tight and minimal over hang with the compound locked out. I rarely used to lock my compound but always keep the tool post from overhanging and use CXA on the 1440. Another thing I practice after lining thing up square and centered to the work piece is looking or studying the chip produced upon introduction of the cutter. This will reveal any issues with alignment. I had parting issues off and on but these steps are crucial on smaller machines to include mine. You might also lock out the carriage when parting and use a steady drip of cutting fluid. Your chips should curl nicely and evenly when all is happy. Good luck amigo!
    sanddan and jbolt like this.
  15. jbolt
    710
    93
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Definitely use the power feed. Hand feeding is difficult to get the feed rate correct and consistant. Its okay for smaller work.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    bigtrev8xl likes this.
  16. woochucker
    102
    43
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
    I don't power feed, always afraid it might dig in, by hand feeding I get feedback. Just my opinion
  17. Randall Marx
    Randall Marx United States H-M Supporter - Premium Content H-M Supporter-Premium
    127
    43
    City:
    Oscoda
    State:
    Michigan
    -Return to Top-
    I always hand feed when parting because I don't have power cross-feed capability. :D
  18. markba633csi
    markba633csi United States Active Member Active Member
    149
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Hacksaw here too. I hate farting off. I mean parting off.
    Mark S.
  19. HBilly1022
    HBilly1022 H-M Supporter - Premium Content H-M Supporter-Premium
    390
    63
    City:
    Barriere
    State:
    British Columbia
    -Return to Top-
    I recently got a bigger lathe 12 x 36 and was very pleased at how easily it parted until the other day when I was having a nightmare trying to part a 1/2" diameter piece of steel. So I checked out some parting videos on Youtube and in one of TubalCain's vid's I noticed he said to never part hot rolled steel, "it's a nightmare". I checked and sure enough that is what I was trying to part. The next few pieces of steel I parted went fine. But I usually don't know what I'm working with since most of it comes from the scrap yard. I did however know these pieces were hot rolled since I got them from the local hardware store. No place near me to get steel and it seems that any project I want to start needs a selection of shapes and sizes and material types I don't have. So I make due with what is on hand. Sometimes it doesn't produce the best product but I'm still learning.:)
  20. unioncreek
    unioncreek United States Active User Active Member
    9
    18
    City:
    Colfax
    State:
    Washington
    -Return to Top-
    Turn the tool upside down and reverse the lathe.
    Bob
    ch2co, HBilly1022 and mikey like this.
  21. HBilly1022
    390
    63
    City:
    Barriere
    State:
    British Columbia
    -Return to Top-
    I've got to try this. The nice thing about is that, is I would be able part off small machine screws without them unscrewing themselves from the bolts that are used to hold them in the chuck. Thanks for the suggestion.
  22. unioncreek
    9
    18
    City:
    Colfax
    State:
    Washington
    -Return to Top-
    I have a Harbor Freight 8x12, my starter lathe. I couldn't part for nothing, speed didn't make a difference it would chatter constantly. I don't know which forum I read it on, but someone else was having the same problem. Another forum member recommended this, so I can't say it was my idea. I can now part at just about any speed regardless of the material. I do slow the lathe to around 140 rpm, but have parted small pieces off at 600.
    Bob
  23. ebolton
    ebolton United States Iron Registered Member
    2
    3
    Newton, New Hampshire
    City:
    Newton
    State:
    New Hampshire
    -Return to Top-
    I don't think this is adviseable if your lathe has a threaded-on chuck, as mine does.
    -Ed
  24. TheGoodLordCalvert
    TheGoodLordCalvert United States Swarf Registered Member
    1
    3
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    I had the same problem/fear with my lathe. Parting would either break the tool or stall the machine. I found a youtube video that mentioned turning the tool upside down and running the lathe backwards, as Bob mentioned above, and now I'm able to part without any problems.
    You could also try using a rear-mounted tool post if you don't want to run in reverse.
    brino likes this.
  25. Sblack
    Sblack Canada Iron Registered Member
    5
    3
    City:
    Montreal
    State:
    Outside US / Canada
    -Return to Top-
    The best book on machining on small lathes is, IMHO, The Model Engineer's Workshop Manual by George H Thomas. It is sold by Tee Publishing in the UK. In it there is a chapter called On Parting Off. He used a Myford Lathe, which is pretty small and he used an upside down tool in a purpose built holder which cut from the far side of the work. Hemmingway sells castings for it. The tool post stayed on the cross slide but the blade could be rotated out of the way when not in use. Because it was running upside down, when the loads got high the tool would flex away from the work rather than digging in.
    http://www.hemingwaykits.com/acatalog/Retracting_Tool_Holder.html
    I don't need such a holder on my super 11 because with an MT5 sized spindle it is pretty rigid. It is all about rigidity. I always hand feed because I can feel when it is cutting well and I can vary the pressure to get the cutting action that I want, which is chips rolling up into curls. You need a good firm oressure, not too light and not too heavy. If the cutter is just plowing or ripping off material I stop and investigate, sharpening or realigning the tool if necessary. Obviously it has to be at center height. If the groove is getting filled with curls I stop and brush them out. I apply cutting oil continuously.
    A lot of cheap chinese lathes and older worn machines won't have good contact on their moving slides. This will make them prone to flexing and chatter. I have seen some where the carriage casting, when sitting on the bed ways, will teeter back and forth due to a the casting having warped after being machined, orobably because it was never stress relieved or seasoned. Good luck parting off with that!
    ch2co and brino like this.
  26. Rockytime
    Rockytime United States Active User H-M Supporter-Premium
    17
    18
    City:
    Arvada
    State:
    Colorado
    -Return to Top-
    I have a MaxiMat7 which is a light lathe. I part in a conventional way with a standard parting blade. I just use lots of ATF fluid. But then I use ATF for everything, cutting, tapping, drilling, etc. I have a Sherline in which I use a parting tool mounted upside down at the back of the lathe.
  27. NortonDommi
    NortonDommi New Zealand Iron Registered Member
    13
    3
    Aotearoa
    City:
    Takapuna
    State:
    Outside US / Canada
    -Return to Top-
    I agree with above comments on upside down tools, I also like to do threading upside down and in reverse. Magic. If a screwed chuck make a rear toolpost and fit a chamfer tool as well, you won't regret it.
    Could I also suggest locking the compound AND the sasddle and making absolutley certain that the blade is at 90 degrees.
    I'll post a pic of toolholder from scrap that works for me this evening.
    In the meantime have a look at this vid.
    Cheers,
    - Barry.
  28. Sblack
    5
    3
    City:
    Montreal
    State:
    Outside US / Canada
    -Return to Top-
    Yes lock everything down. In the book I describe above George Thomas (GHT) shows a locking cross slide and compound. Anything that helps reduce flexing. A sharp tool on center is also essential. GHT used to demonstrate parting off 1" cold rolled steel at 300rpm at the Model Engineer expo in England just for "showmanship". He does admit yhat on his furst lathe, which was foot powered (!) he was reduced to using a hack saw. As his lathes grew in spindle size his success at parting improved as well.
  29. firbikrhd1
    firbikrhd1 United States Active User Active Member
    5
    18
    State:
    Florida
    -Return to Top-
    Parting seems to be difficult for almost everyone, including me, until you learn the "secrets" (which are really simple steps that must be followed to a "T" in order to be successful.) I respectfully disagree with those that say parting cannot be accomplished on a small lathe. I have successfully performed parting on my 1943 Logan 10" lathe as well as my dad's old worn Atlas 10" bench lathe, a model which many say is not very rigid. On both lathes I have been able to reliably part by both hand and power feed. I am an amateur machinist with no claim to expertise, however these are the keys to success for me:
    #1 Rigidity of the work. The cut should be made as close to the chuck jaws as possible. Certainly no more than two diameters of the work away from the chuck jaws. Closer is preferable. DO NOT attempt to part between centers in an attempt to achieve rigidity. You will likely break your parting tool toward the end of the cut or damage the work..
    #2 Rigidity: If the chuck's jaws are bell mouthed you cannot maintain rigidity of the work, no matter who much you tighten the chuck jaws. If you are using a lathe with a threaded spindle be certain there are no chips in the threads of the spindle or the back plate and of proper fit between the spindle shoulder and the chuck back plate. There should be full contact at those points if the backplate is properly fitted. Blue those areas and install the chuck then remove and look for blue that has not been removed. Those are areas with no contact, correct the fit. The portion of the spindle shoulder I speak of is the one that the back plate butts against, not area that enters the backplate bore. (Without getting into a huge debate about how back plate bores should fit the spindle I'll say that I subscribe to the belief that the threads, due to their 60 degree form, center the chuck on the spindle to prevent runout and that the shoulder the backplate butts against holds the chuck true to the axis of the lathe ways. Others may disagree, and that is fine, but that debate is like debates on which oil is best, circular and without end.)
    #3 Rigidity: The tooling must be set up as rigidly as possible. If you are using a Lantern tool post ditch the rocker and make a solid steel ring of a thickness that puts the tip of the parting tool on center. With a QC tool post be certain there are no chips under the tool post and that it fits the compound flat without rocking. Compounds can have worn surfaces from years of use that will not allow tool posts to be rigidly mounted. Dings from dropped tooling will cause raised areas that allow minute rocking and ultimately chatter. Be certain that the parting tool does not extend any further from the holder than is necessary regardless of what tool post you use. If using a Lantern tool post choke up on the tool holder as much as possible. Keep overhang to a bare minimum.
    #4 Rigidity: Think about every possible way for movement to creep into your setup and eliminate it as much as possible. Properly adjusted machine gibs, small tool overhang, tight tool posts, holders etc. Be certain your headstock bearings are properly adjusted if they are plain type or have proper preload if of ball type.
    Up to this point most of what has been said is appropriate for accurate chatter free plain turning and boring as well as cutting off. Much is just general good practice for machine maintenance.
    #5 Parting tool alignment. The parting blade must be perfectly perpendicular to the work and on center. Take great care in assuring this. I usually use the lathe chuck as my guide and put the parting bit right up against it. I use a white piece of paper or a light shined from below to adjust the tool holder/post until the light coming through shows an equal space at the blade tip and where it meets the holder at the outer perimeter of the chuck. I use the same care I would when I set up a threading tool for a threading operation using a Center Gauge. The parting tool must also be perfectly vertical. If it leans one way or the other it will rub on one side and track to the other.
    #6 No back rake on the parting blade itself. It should be on centerline of the work and level. Be certain there is adequate front clearance or the tool will rub rather than cut and of course there should be side clearance on both sides of the blade. If the cross feed requires much pressure when attempting to part be certain to check front clearance, the tool is most likely rubbing due to lack of front clearance or is adjusted above center. The blade should be sharp and honed to a fine edge at the tip and sides. Some advise grinding the tip at a slight angle to eliminate the tit left on the work. I do not do this as it seems to make the narrow parting blades I use try to wander to one side. I grind my tip so it is perfectly parallel to the work.
    #7 Once you have the cutoff tool position where you want the cut lock the carriage to the ways.
    #8 Speed. I generally use speeds of about 1/2 to 2/3 that recommended for turning whatever material I am parting. Don't be afraid to try a faster or slower speed if chatter develops. Note that chatter is a sign of lack of rigidity. Check again to assure you have done all you can to assure a rigid setup.
    #9 Feed. Start with hand feeding, feed slowly but steadily and with enough feed to produce a thin continuous chip (in steel or aluminum). Be aware of tool pressure. The tool should feed in easily if there is enough front clearance. The chip should come off as a curl when everything is right and will roll up on itself. When conditions are right I get a curl that looks much like what the curl of metal that is produced when using a key to open a can of sardines. There is a distinct sound when all is well. To me it sounds like a hissing or tearing sound.
    #10 Lubrication. Continuous lubrication should be applied while parting. If you don't have coolant pumped (I don't) use a brush and flood the cut. I find that I can usually work the hairs of an acid brush deeply enough into the kerf to keep things lubed adequately. I use dark cutting oil on steel and stainless and WD 40 on aluminum although the dark oil will work on aluminum as well.
    #11 Once you have gotten the hang of feeding by hand and knowing what RPM to use you can mimic the feed rate with your power cross feed.
    #12 RIGIDITY! Truthfully that is 70% 0f success so it bears repeating. Do all you can to make everything as rigid as possible. The other 30% is tool alignment and front clearance.
  30. NortonDommi
    13
    3
    Aotearoa
    City:
    Takapuna
    State:
    Outside US / Canada
    -Return to Top-
    WOW! Firbikrhd1 you have said everything that needs saying. Great stuff.
    Hear's those photo's I said I'd post, please excuse the state of the lathe, it does actually get cleaned on a regular basis.
    The toolholder needs to have countersink screws but it was knocked op in an hour with what came to hand from the scrap bin.
    P.S. Scrap machinery like computers, washing machines, old microwaves are a good source for odd screws ect.
    I hope this will be of help.
    -Barry.
Share This Page
