- Jun 7, 2013
- 10,007
I have yet to see 1-2-3 blocks made of anything but hardened steel, so not so good to scrape. Start with a cast iron block of some sort that is smaller than your surface plate, and learn to scrape on that before taking on something larger or more complicated. As far as the scraper is concerned, I started with a file that I forged down thin on the end, re hardened it, and sharpened it carefully, and used it a good bit until I was able to "acquire" a insert type holder made by Sandvik, where the insert clamps into the end of the shank, from where I worked at the time back in the 1960s; I am still using the same insert, they last a long time with careful sharpening . Just any old carbide does not make the grade here; the inserts are made of carbide that is very fine grained and very hard, and need a diamond wheel to sharpen; green abrasive wheels cause chipping on the cutting edges which give poor results on the scraped finish. The inserts are available from Biax, and are not at all cheap, but will last many years. After you have taught yourself to scrape and get good results, then go on to more ambitious projects, and you may want to attend one of Rich King's scraping classes, as Ulma Doc and I both have done and really learn how to do it from a professional; his classes are geared to the beginner, and you will learn to do it the right way, both hand and power scraping; he has videos as well.IMHO, i'd do the 1-2-3 blocks first.
they are cheap, they are readily available and easy to work with.
you'll get an almost instant sense of accomplishment that will give you confidence to try something larger and so on.
if you want a simple but satisfying project.
make your own hand scraper from an 18" piece of 1"x1/4"thick CRS flat bar, a handle, and a simply brazed or silver soldered carbide toolpoint.
you will of course need a carbide capable or diamond wheel for the grinding mechanism to dress the carbide tip.
an old file can also be ground down to the correct shape for performing scraping operations as well, you'll just be resharpening the cutting edge a lot more than using a carbide toolpoint
