I have just hauled a SB9 home after disassembling it to move and reassembling it. I think it is a model C. The only light oil I have on hand is 3 in 1 oil. The lathe was bone dry an unused for years. I cleared the oil ports of sawdust and gunk best I could with a drill bit to pull out the gunk and applied the 3 in 1. I have not run the lathe and did not let the seller start it. the spindle turned easily by hand and the AC cord on the motor was extremely disintegrated. I need to know it the 3 in one is a problem? What is the recommended oil for the motor, head stock and ways also all the small oil ports. the How to run a lathe books indicates different oils for different parts. No mention of the motor fill caps.
My lathe did not come with the little wheel gizmo that you watch to engage the half nuts to cut threads. Do I have to get this or can you cut threads without it?
Lots more questions to follow, one on top is a safe way to remove the stuck 3 jaw chuck. I have tried the book method of a piece of wood against the bed, engaging the back gears and working the pulley to break it free.
I will have the rewire done this evening and the switch reassembled and mounted. Can I run it with the oil I have or wait and buy thinner stuff?
thanks in advance. JB
