- Jun 7, 2013
- 10,074
Another thing that I like about the Last Word indicator is its mounting method with the friction swivel connectors; it sets up and adjusts easily with a minimum of parts. I do have a B&S, but use the Starrett much more.
The screw adjustment (under the feeler) has an effect on slop, as the arm does not fully engage with the spiral slot in the pointer shaft if it (the screw) becomes loose.I bought one of these for $98.
http://www.ebay.com/itm/NOS-COMPAC-...-0-0-01mm-Graduations-WL13-4-11-/172528481406
It had so much hysteresis I sent it to Mark R. for a going over. I can't remember exactly what he did but it is better but still has it. Very annoying imo.
Not sure if i would buy another.
Possible that this model may be low on the totem pole.
