When did they switch to the newer style table?
VAN NORMAN No. 12 TABLE CHANGES
Hi Jason,
Sorry it took me a while to respond.
As best I can tell, there were three different tables used on the No. 12. Most of the machines built in the 40s have a table with a cast lip above the T-slot in the front of the table (the T-slot is for the feed stops). Older machines, like yours, have a table that’s flat on the front, with no lip over the feed stops. The machines built towards the end of production in the 50s have a table that’s similar to the 40s vintage table, but has a separate bracket for the left hand-wheel (the earlier designs incorporated the support for the left end of the leadscrew into the table casting.
The oldest manual that I have, for the ball-bearing gearbox machines, shows the table with the front lip, but brochures from about the same time show No. 12s without the lip. So just when the change happened is a bit of a mystery.
I have big gaps in my photo archive, but machine 12-5251, built in 1938, has the old style table. 12-6294, built in 1941, has the middle style. 12-9566, built in 1951 has the later style table.
Your machine is interesting since it has extensions bolted to the front and back of the table. I don’t have any photos of other No. 12s with that feature.
