  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Huanyang Vfd Wiring & Setup (vfd Newbie)
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by jbolt, Mar 29, 2015.
  1. jbolt
    jbolt United States Active User H-M Supporter-Premium
    605
    93
    City:
    Mountain View
    State:
    California
    Hi All, I'm to the point on my mill belt drive conversion that it is time to setup the VFD / Motor. This is my first VFD so I need some guidance getting it setup properly. The Huanyang VFD and Hallmark motor were free to me so I will be using these for the first go. If I am not satisfied with the performance I will upgrade to better equipment later.
    Here are the VFD and motor labels.
    First I want to verify I have the base wiring done correctly. The VFD is 220v so I have the motor wired in the "Low Volt" configuration.
    Three wires from the motor "U/L1", "V/L2", "W/L3" go to the corresponding "U", "V", "W" terminals on the VDF.
    Motor ground from the motor case ground screw to the ground terminal in the VDF (lug to the right of terminal "W")
    Motor shield wire unattached at the motor end and terminated at the VFD chasis ground.
    Main 220 power is L1 and L2 from a contactor to terminals "R", and "S" on the VFD.
    Main ground wire to the VFD chasis terminal.
    I have not powered it up yet.
    If the base wiring looks good then what is the next step in configuring the VFD?
    The VFD will be controlled from Mach3 through a PMDX126 BOB, Eithernet Smooth Stepper and PMDX-107 motor control card.
    I'm thinking it would be best to get the VFD/motor running off the key pad before doing the Mach3 setup???
    Jay
  2. mksj
    mksj Active User H-M Supporter-Premium
    990
    113
    City:
    Tucson
    State:
    Arizona
    The way you have wired it looks correct. You should have the incoming single phase power fused or going to a breaker before start-up. You should do basic programming before running the motor, i.e. enter the motor parameters (PD141-144) into the VFD. Base frequency should be 60Hz (PD176). Agree, make sure everything is working manually before external controls are added. If you require very quick brake times, you might need to add a braking resistor, but less of an issue on a mill vs. lathe.
    JimDawson likes this.
  3. awander
    awander United States Active User Active Member
    13
    18
    City:
    Upper Black Eddy
    Make sure your motor is wired per the "low voltage" diagram.
  4. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    Thanks guys, I do have circuit breakers before the contactor and the motor is wired for Low Volt.
    Once I actually started pushing buttons it's pretty straight forward (if you understand what the parameters do). The Commissioning part of the manual is terrible for understanding what buttons to push.
    Okay here is what I programmed.
    pd001 = 0, run command = operator (manual)
    pd003 = 60.00, main frequency
    pdoo4 = 60.00, base frequency
    pd005 = 120.00, max frequency
    pd008 = 220, max voltage
    pd141 = 220, rated motor voltage
    pd142 = 8.0, rated motor current
    pd143 = 4, motor pole number
    pd144 = 1725, rated motor revolution
    pd176 = 60.00, inverter frequency standard
    Motor started and ran fine with no load, I ran it no load for 30 min . I then hooked up the belt to the the 1:2 ratio pulleys and ran the spindle for 30min at 60hz. And last I swapped to the 2:1 ratio pulleys and ran it at 60hz and then 120hz for 15 min each. The outside of the motor case stayed a constant 108 deg which I think is reasonable.
    So far I think I have the base programming correct. Please let me know if anything above looks wrong?
    I do have some noise/vibration coming from the splinded shaft area of the spindle which I think is the somewhat loose fit of the splined drive sleeve to splined spindle shaft connection but that problem is for a different thread...
    Next step is getting Mach3 setup??? More reading to do.........
    Jay
  5. stupoty
    stupoty Active User Active Member
    195
    63
    City:
    London
    I have two of the hy brand invertors, one has earth continuity on the two lower screws marked with earth symbol, the other one dosn't. Definetly worth a check.
    Stuart
  6. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    Thanks Stuart I will check!
    Jay
  7. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    I need to verify the wiring from the motor controller (PMD-107) to the VFD.
    This is what I have come up with.
    PMDX-107 ---> VFD
    Pin 6 - Rev/Dir REV (reverse run)
    Pin 5 - Fwd/Run FOR (forward run)
    Pin 4 - COM (common terminal for relays, pins 5 & 6) DCM (common terminal of digital and control signals)
    Pin 3 - Aref (not used)
    Pin 2 - Aout (spindle speed anolaog control voltage) VI (analog voltage frequency reference input)
    Pin 1 - Agnd (VSD ground reference) ACM (common termnal of analog and
    PMDX Config settings (dip switches)
    Config 1 = Off (Normal Mode)
    Config 2 = Off (Normal Mode)
    Config 3 = Off (relays operate as for and reverse control signals)
    Config 4 = Off (charge pump signal required)
    Slow = Off (fast PWM filter response)
    5v/10v = Off (10v reference)
  8. mksj
    990
    113
    City:
    Tucson
    State:
    Arizona
    Just a note on the motor settings, probably would use PD005 of 90 or 100Hz, unless you have some information that indicates a higher top speed. 120Hz may be OK for short periods of time, but not sure I would run this particular motor for long periods.
  9. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    It was my understanding that these motors would tolerate up to about twice their rated hz? Maybe I am mistaken or that is for a higher quality motor?
    I was planning on limiting the spindle to 6k which works out to around 105hz. Would that be okay?
  10. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    I just realized the formatting got screwed up on post #7
    Try again,
    PMDX-107 ---> VFD
    Pin 6 - Rev/Dir ----> REV (reverse run)
    Pin 5 - Fwd/Run ----> FOR (forward run)
    Pin 4 - COM (common terminal for relays, pins 5 & 6) ----> DCM (common terminal of digital and control signals)
    Pin 2 - Aout (spindle speed analog control voltage) ----> VI (analog voltage frequency reference input)
    Pin 1 - Agnd (VSD ground reference) ----> ACM (common terminal of analog and control signals)
    Slow = Off (fast PWM filter response) (may need to be changed to slow if VFD cannot keep up)
  11. mksj
    990
    113
    City:
    Tucson
    State:
    Arizona
    It is my understanding that the bearings are the same, so it is not necessarily a mechanical limitation. There may be some limitations as to developing full horsepower out to 2X rated speed and torque can fall off in a somewhat more non-linear manner above 1.5X base speed. A lot depends on the motor specs, so motors like the Marathon BlueMax and BLackMax 3 phase 1750 RPM motors are rated up to 5-6K. Most of the better built 3 phase motors are OK up to 2X base speed. Just wouldn't push the motor hard for long periods at the higher RPM.
  12. countryguy
    countryguy United States Active User Active Member
    168
    43
    Fenton, MI
    City:
    Fenton
    State:
    Michigan
    If I recall, there are true Inverter rated motors w/ special insulated armature windings and current capabilities. There were also issues w/ the heat dissipation on non-VFD rated motes. On these better VFD Motors, a higher temp capability is then allowed based on higher currents when pushing Hz up. I'm sure the Bearings have some manner of heat rating as well so thats possibly a factor. Non-Inverter rated motors and older motors can melt down and burn up. I posted a link to some images in the past. I think when we say up to 2x for short times, we are simply exercising the older motors saftey margins for sake of speed. That's what I recall on a really Sunny 55' day here in MI.
    CG.
  13. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    Steve Stallings at PMDX confirmed my control wiring and I can now turn the spindle on/off with Mach3. My only problem at this point is I cannot get the spindle speed to change with "S" commands. It always goes to 100%. I can slow and speedup the spindle with the override.
    Jay
  14. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    Thanjs for all the feedback so far. I am still looking for a solution as to why I cannot control the spindle speed with "S" commands in Mach3.
    These are my settings.
    PMDX-126 BOB, PMDX-107 Motor Control, ESS Motion Controller.
    MOTOR, 220v, 2hp, 3ph, 1725rpm, inverter duty, class F
    VFD = Huanyang HY02D223B Settings
    pd001 = 1, run command = external terminals
    PD002 = 1, operating frequency source = external terminals
    ESS Settings
    SPINDLE
    PWM, base hz 25
    Mach3 Settings
    RELAY CONTROL, disabled
    MOTOR CONTROL
    Use Spindle Motor Output
    PWM Control
    PWM Base Freq = 25
    Minimum PWM 5%
    SPINDLE MOTOR TUNING
    Steps per = 1000
    Velocity = 60
    Acceleration = 5000
    PULLEY SELECTION
    Pulley 1, Min Speed = 300, Max Speed = 6000, Ratio = 2 (4" motor pulley, 2" spindle pulley)
    Pulley 2, Min Speed = 75, Max Speed = 1500, Ratio = 0.5 (2" motor pulley, 4" spindle pulley)
    Thanks
    Jay
  15. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    I finally figured out the final piece of the puzzle. PD072 was factory set to 400hz and was screwing up the scaling. I reset this to 105hz and reran the built-in calibration on the PMDX-107 motor control card. I was able to tune the max spindle speed to 6000 rpm and now the scaling in Mach3 works perfectly.
    Jay
  16. cathead
    cathead Active User Active Member
    343
    63
    City:
    Bemidji
    State:
    Minnesota
    Greetings,
    I just purchased a HuanYang GT series inverter (7.5KW) and the instructions are unclear to me. RSandT are the inputs but no where in this manual can I find
    a reference to which input wires go where for 220 volt single phase operation. I think R and S are the 220 inputs but don't know where to hook up the neutral wire, my guess is to ground and not
    the T terminal. The manual is lacking in my opinion. I'm hoping someone knows.
    Thanks.
  17. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    On my 2.2kw unit it is a 3 wire hookup for single phase Line 1 and Line 2 of the 220 go to R & S and Ground to the Ground terminal. T is for a 3-phase input and not used. Neutral is not used for the VFD.
    Jay
    cathead likes this.
  18. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,198
    113
    City:
    Sandy
    State:
    Oregon
    Do Not connect the neutral to the VFD. It would be a direct short!:chemist:
    The 7.5KW VFD is not really designed for single phase input, but according to the manual you can connect to any 2 of the R, S, T terminals for single phase operation.
    cathead likes this.
  19. cathead
    343
    63
    City:
    Bemidji
    State:
    Minnesota
    Jim,
    Thanks for responding. I was hoping to hear from you. Do I leave the neutral unconnected or can the neutral be applied to the ground lug?
  20. JimDawson
    3,198
    113
    City:
    Sandy
    State:
    Oregon
    Just leave the neutral unconnected, it is not used in this circuit. But do connect the ground to the ground terminal.
    cathead likes this.
  21. cathead
    343
    63
    City:
    Bemidji
    State:
    Minnesota
    OK, I understand now. Your knowledge and assistance is much appreciated.
    I can't thank you enough! Burt
  22. JimDawson
    3,198
    113
    City:
    Sandy
    State:
    Oregon
    Thank you for the kind words. It's my pleasure to help out where I can.
    cathead likes this.
  23. stupoty
    195
    63
    City:
    London
    How do us 220v circuits work ? are they phase + phase ? (2 x 110v out of phase ?) as
    Maybe we should have a sticky or something some ware, Just realized that us 220v is phase and phase where as European 220v is single phase, i.e. live and neutral go into the VFD input hear.
    Stuart
  24. JimDawson
    3,198
    113
    City:
    Sandy
    State:
    Oregon
    Our neutral is derived from a grounded center tap on the transformer. I should note that I looked at the OP's location before I made my recommendations. If he would have been in Europe or GB, my answer would have been different.
    L14-3.gif images?q=tbn:ANd9GcQ5dKXa4HQwj84xyW3J6dFYjBpEepijRm9hoylvEHrCwxXsMqSH.jpg
  25. mksj
    990
    113
    City:
    Tucson
    State:
    Arizona
    Nice chart on the wiring and differences. I believe the terminology is the US 240V is split phase, EU would be single phase 240V. VFDs used in the US that are 220-240V single phase are hot to hot, there are also 120V in that are hot and neutral and they output 3 phase 200-240V. Neutral should not be tied to ground except at the main electrical box.
    Fitter Bill, cathead, sanddan and 2 others like this.
  26. sanddan
    sanddan Active User H-M Supporter-Premium
    477
    63
    City:
    Damascus
    State:
    Oregon
    Thanks guys for the electrical class, great info to bookmark.
  27. dooshare
    dooshare Canada Iron Registered Member
    1
    3
    City:
    sherbrooke
    State:
    Province du Quebec
    Hi Jay I did a posting http://www.hobby-machinist.com/thre...-to-a-tb6560-3-axis-driver-blue-boards.48391/
    and hope you can help me as it looks like you connected your VFD to Mack3 thanks
  28. jbolt
    605
    93
    City:
    Mountain View
    State:
    California
    Hi dooshare,
    Welcome to the site. I'm not familiar with your board but it looks like it has built in spindle support. It there a manual for the board?
    I'm at work now but I can take a look later tonight to see if I can help but in the mean time you should post this in the" CNC in the Home Shop" forum so it will get better exposure to the CNCer's on the forum.
  29. dooshare
    1
    3
    City:
    sherbrooke
    State:
    Province du Quebec
    Thanks Jay, i reposted it under CNC home shop with more info and photos.
  30. BillyT
    BillyT Canada Iron Registered Member
    1
    3
    City:
    Clavet
    State:
    Saskatchewan
    hey Jay, why does the max hertz have to be set to 125, should it not be 220....fyi i'm a fng
Share This Page
