How To Reverse Rotation Of 1 Phase Motor?
trg-s338
Apr 3, 2011
74
I've acquired a Delta brand model 62-185, Marathon manufactured single phase motor I want to use on my just built belt grinder. It is 2 HP, 10A, 230V, C-face motor. May have originally been on a Delta DC33 Planer. My knowledge of electric motors is limited but in searching information, I've come to believe this is a capacitor start-run motor. It has a 30 uF as well as a 230-276 uF capacitors on it. I assume the larger one is the start capacitor disconnected by a internal centrifugal switch at the appropriate speed. This motor spins counter-clockwise and I need to reverse the rotation. I hope to not have to dismantle/remove the end bell of the motor. Can reverse be achieved by simply switching start capacitor terminal wires (colored red and yellow, a black wire connects both capacitors)? If not, I could use some advise on how to go about it? The power switch/fuse box has a blue and red wire to it from the motor. Your thoughts on this would be greatly appreciated. Thanks.
a picture of the wiring end of the motor would help.
some motors are not reversible, some are reversible
The start winding has to somehow be reversed. On reversible motors, the winding leads are brought out to an access point where they can be interchanged. One end of the winding may be connected to the start capacitor or to the centrifugal switch. The winding, the start capacitor, and the switch are wired in series and can be reversed as a unit if the winding leads are not accessible. On unidirectional motors, the windings may be connected internally. I have successfully traced down the internal connections and reversed them but it required a teardown of the motor to get at the leads. There are a number of threads on the site which have wiring diagrams for capacitor start/capacitor run motors. A search should pull them up. Try http://www.hobby-machinist.com/threads/another-wiring-job.32378/#post-274656 for one.
Opened up the back of the motor. Attempting first time upload of photos. Within the back plate is a switch that looks like contact points on auto engine distributor of old. This is positioned between the capacitors it seems.DSCF2864resized.jpg DSCF2866resized.jpg DSCF2873resized.jpg
Are there no wiring diagrams on the data plate on the motor? Maybe inside the switch box?
It looks like you have a unidirectional motor. If the motor is unidirectional, it usually state CW or CCW on the data plate.
I see the two feed (red and blue)wires coming in from the black box. One of the yellow wires runs from the capacitor to the switch. It looks like a brown wire runs from the switch to the capacitor?
Most likely the other end of the start winding is connected to the run winding somewhere. The connection probably be taped over. It would be necessary to break that internal connection and run that end the start winding to wherever the other end of the winding is connected and to connect that other end to the internal connection point. In other words, swap the leads end for end. Before changing anything, identify the winding leads with an ohmmeter or circuit tracer.
Changing rotation on a unidirectional motor isn't difficult but you have to pay attention to details. If you think it is too complicated, consider mechanically reversing the motor. If that is not possible, an electric motor repair shop should be able to reverse the direction.
From what I see, I've drawn a schematic. I teased out the blue wire end of the windings and find three wires attached to it. Two of the wires beep continuity with the Yellow "B" side of the centrifugal switch. The third wire beeps continuity with the red wire off of the large 273 uF black capacitor.
* Would it be correct to presume that one of the 2 wires continuous with the "B" side switch is the other end of the start winding and is dropped out when the motor is at speed? Any guesses on what that second wire to the "B" side might be? This throws off my schematic.
* Would it also be right to presume that the 3rd wire that communicates with the red wire of the 270 uF large black capacitor is the run winding?
It's very likely my inexperience leads to some wrong conclusions here so I'll value any input on this. Thanks for your time.
Your schematic is incorrect. The centrifugal switch must disconnect the 270mfd start capacitor when the motor is up to speed while leaving the 30mfd run capacitor in the circuit. The run winding must always be connected across line and neutral.
I removed the switch from the back plate and discovered my error as you prompted me John, thanks. I corrected the schematic. The continuity test results are as above but I have a sense that I've got my conclusions on the windings backwards. Still at a loss on the the third wire at the blue lead.
Note that reversing *either* winding (but not both) will reverse the motor.
