- Sep 22, 2010
- 7,223
I recently acquired 4 Gits oil hole covers along with some other parts. I believe they are older models as they are made of brass and the newer ones listed on the Gits Site are made of steel. I don't know if the new steel ones have the hinges soldered or spot welded on. If they are soldered on I believe the procedure outlined below will work for them as well.
1. The needed tools are shown in picture 1.
2. Using an X-acto saw carefully cut away as much of the tube around the hinge as you can. See picture 2.
3. Hold the Soldering Iron to the inside of the hinge (picture 3) and hold the cap with a pair of small pliers. Gently pull on the cap, keep tension on that cap. Patience is needed here. The cap will come off, it just takes longer than you think it should. Heat is your fickle friend. Too much and you ruin the spring; just right, the solder melts and the cap assembly comes off. See picture 4. (I tried using a small propane torch on an earlier attempt and ruined the spring.) If you do it right the cap assembly will still have that “snap†in it after it is removed.
4. Clean and flux the old tube. Next locate the end of the spring that is wrapped around the hinge. Make sure you get the spring on the outside of the tube when pushing the hinge on the old tube. If you don't, the spring will likely break off and the "snap" with it (I made this mistake as well.) I used a small pair of tweezers to pull it out of the way. Get it all lined up and re-solder the cap in place. See picture 5.
