- Jul 20, 2012
- 1,237
I have some solid non bearing bronze I could use but thought I would try to make this work. It is not important, just a project. My brother sells custom shaving brush handles and I make some different ones for him when I get the time. For me is is nice to be able to do some simple work for fun and give them to him to get what he can for them. You'd be surprised what people pay for custom one of a kind things. With solid bronze it is very heavy so the aluminum filled bronze has a lighter feel but I ran into this issue.
It was a bearing with a one inch center and I pressed a piece of aluminum through it. Plan is to use the longer aluminum part to hold it in the lathe until I cut it off and bore out the 22mm socket for the brush to be put in. I only machined the ends a little shorter so didn't cut the surface.
Before treatment when it blackened fingers easily:
After degreasing with brake cleaner and soaking in hot water and Dawn soap:
The discoloring is actually nice and it is a distressed piece, more old scratches the better.
Right now it doesn't make any black on the fingers but feels mildly oily.
I might go with heat, maybe acetone.
